brutal engine noise
Discussion in 'Gen 2 Prius Technical Discussion' started by rrmtinc, Sep 23, 2012.
  1. rrmtinc
    rrmtinc New Member
    Our 04 Prius makes a really scary metallic noise at the top of the engine when it is engaged. All maintenance has been performed within 100 miles of the warning light. We are the original owners and the car has 160k miles. No pulleys are touching their surroundings. Make no mistake, this a LOUD noise that has been growing with time. No warning lights,,,oil level is fine,,,and no metal visible on the dipstick. Sound is originating at the top of the engine and is not a "knock". It is more of a metal on metal type of noise. Hopefully someone knows what is could be and not what I feel it is.
    49,435
    at 160k it could be almost anything. are your mpg's changing? oh, welcome to p/c!
  3. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Try the easy things first.
    The GenII has a belt to drive accessories. Try removing the belt and running the engine for a few seconds to see if the noise goes away. Don't run it for more than a few seconds without the belt or your engine will overheat.
    If the noise goes away, check the idler pully for roughness when turned, noise or looseness. A lesser possibility is the water pump if the noise goes away when the belt is off.
  4. northwichita
    481
    102
    29
    Wichita KS
    Still unknown?
    If not external to the engine (also my first guess) I would take off the valve cover and check as you say, the top of the engine.
  5. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Yes, I would check the lifters and valve adjustment. :( H
