BT phone function only working one way
Discussion in 'Prius c Audio and Electronics' started by Nel, May 30, 2013.
  1. Nel
    Nel Member
    174
    84
    SF Bay Area
    So far, all the electronics work just as expected (granted the car is really slow to load up the software), except for one thing. I can NOT make a call through the car itself, voice activated or via the touch screen. The headunit shows a phone call in progress, and immediately disconnects from the phone call (as if I have no cellular signal). I CAN, however, make a call directly from my phone and the call will go through the headunit
    My entune system is updated, and my phone is an Android (Samsung Galaxy Nexus). Everything else works, so I'm not sure if this might be a common problem.
    Any thoughts?
  2. RocMills
    RocMills Active Member
    789
    276
    Las Vegas, Nevada
    I don't have the Entune setup (C2 here), but I have similar issues with my phone connected to the car. I cannot make a hands-free call... I must dial the physical phone and after it has started dialing the car takes over.
  3. nklb
    nklb Member
    111
    I saw this behavior a couple of times on my 2012 prius liftback when I was running an old headunit firmware, 1.8.4, but it would always start working again in a few minutes inexplicably.
    I haven't had much time with 2.2, but so far I have not seen the problem with it.
