BT Plate install
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Rxmxsh, May 2, 2007.
  1. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    Is it ok just to get under the car and do it while the car is on the ground? i don't have a place i can jack the car up on, and it sounds like some of you have done it without jacks....
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(Rxmxsh @ May 2 2007, 08:56 PM) [snapback]434423[/snapback]</div>
    You won't be able to reach what you need without ramps or jacking it up...not enough clearance.
    I suggest investing in some ramps...not very expensive and very useful any time you need to get under there.
  3. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    If you're thin/small enough (think gnomes), you can get under the car and just install the plate without jacking it up. If you have a sloped driveway, you could position the car at the top of the driveway with the end hanging off the slope.
  4. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    <div class='quotetop'>QUOTE(Presto @ May 2 2007, 06:59 PM) [snapback]434426[/snapback]</div>
    Got it! WOW what a difference! Very easy install...
  5. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    <div class='quotetop'>QUOTE(Rxmxsh @ May 2 2007, 08:17 PM) [snapback]434482[/snapback]</div>
    Let the naysaying begin... :rolleyes:
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    You calling me a Gnome because I installed mine without jacks? :angry: Hahaha kidding!
    I did install it without jacks or parking half off the curb. I'm 6'3" and 160lbs wet.
  7. BT Tech
    BT Tech New Member
    885
    South Florida
    GREAT job F8l!! We have had some customers that are able to install our BT plate just in the manner that you did. Another popular way was to find a small curb and drive the front wheels over it that would provide more clearance under the middle of the car. Of course you should make sure that the car is in PARK, emergency brake is ON and block all wheels to prevent the possibility of movement!!! (End of disclaimer) :)
    <div class='quotetop'>QUOTE(F8L @ May 3 2007, 03:26 AM) [snapback]434588[/snapback]</div>
  8. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    <div class='quotetop'>QUOTE(BT Tech @ May 3 2007, 09:39 AM) [snapback]434803[/snapback]</div>
    That how i did it too. Just took a socket to remove, and a torque wrench to add. 15 mins. TOPS. No need to be gnome size. i'm 5"10 - 168lbs.
  9. jaybee
    jaybee Junior Member
    27
    Atlanta, GA
    I have a question. Last weekend I had a friend install the BT Stiffening plate for me as he's a car enthusiast and he owns all of the tools necessary for installation. He jacked up the driver's side of the car and placed jack stands under the front and back and then removed the old plate and installed the new one.
    My question is, is it ok that he installed the plate with the driver's side of the car up in the air with the passenger side wheels on the ground, or would it have been better to raise either the front or back of the car. Or does it even matter?
    Thanks,
    Jay
  10. BT Tech
    BT Tech New Member
    885
    South Florida
    No worries Jay, you will be fine and are good to go!! :)
    <div class='quotetop'>QUOTE(jaybee @ May 4 2007, 02:29 PM) [snapback]435574[/snapback]</div>
  11. jaybee
    27
    Atlanta, GA
    Thanks Brian!
    <div class='quotetop'>QUOTE(BT Tech @ May 5 2007, 01:03 PM) [snapback]436060[/snapback]</div>
