BT stiffening plate installation
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ernda, Mar 31, 2006.
  1. ernda
    ernda New Member
    43
    Beverly Hills, CA
    I could probably install the stiffening plate myself with some effort since I don't have jackstands and I would havfe to rent a torque wrench. Has anyone in the Los Angeles area had this installed by some pros who could recommend them? Thanks
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    I did it myself and didn't need any of that.
    I crawled under the car and did it. I put down a piece of plastic so I could slide. I used a wrench I had from a tool I bought to fix my bicycle....multiple sizes. Just found the one that fit and hand tightened. Just made sure I didn't tighten too much. Guy at Pep boys gave me some advice when I saw what he wanted to sell me I already had at home.
    BTW I'm a 51 year old Reubenesque female and I didn't have any trouble doing this. It took more courage than brawns or brains.
  3. espoafd
    espoafd New Member
    88
    Albuquerque, NM
    It really is an easy install. If I lived in the area I would be glad to do it for you. Maybe some other PC member living in close proximity to you could help out.
  4. Begreen
    Begreen Member
    670
    Western WA state
    I did mine at the local friendly garage. I already had the 12mm socket, but no hex key large enough. They loaned me a socketed, metric, allen key on a torque wrench. I worked right in their lot and didn't need to jack up the car, just reached under and went to work. It's really easy, 4 bolts all within arm's reach. Had the plates swapped in 15 minutes.
  5. J.Wilkie
    J.Wilkie 80 Mile Daily Commute
    157
    Behind The Orange Curtain
    Yeah it's so easy, I did mine in my driveway!
  6. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(Begreen @ Mar 31 2006, 06:21 PM) [snapback]233216[/snapback]</div>
    Man, I LOVE to hear that places like this still exist!
  7. Begreen
    Begreen Member
    670
    Western WA state
    <div class='quotetop'>QUOTE(darelldd @ Apr 1 2006, 03:49 PM) [snapback]233523[/snapback]</div>
    Me too. I gave the young mechanic $5 and thanked him. He said no, but I insisted. A good deed needs to get rewarded sometimes. Made my day. Island living at it's best.
  8. charlieh
    charlieh Junior Member
    Did both my '04's in the driveway. I did buy a set of hex sockets at AutoZone. Whole process took about 15 minutes per car. I did use a torque wrench that I have owned for years and used about 5 times - so it did come in handy again. I did not use jack stands - just worked the bolts from each side of the car.
  9. Roger3125
    Roger3125 New Member
    199
    Orange County, So Calif
    <div class='quotetop'>QUOTE(charlieh @ Apr 3 2006, 04:31 AM) [snapback]234079[/snapback]</div>
    Got my Chassis plate today. Yippeeee!!!! Now all I need is someone to install it for me. Can someone recommend someone in Orange County, CA Tustin/Orange/Santa Ana area? Sure would appreciate it
    Thanks
    Roger
  10. BT Tech
    BT Tech New Member
    885
    South Florida
    Congrats on receiving your new stiffening plate!! Please post your impressions when you have a chance to get in installed.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
    <div class='quotetop'>QUOTE(Roger3125 @ Apr 4 2006, 12:32 AM) [snapback]234543[/snapback]</div>
  11. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Begreen @ Mar 31 2006, 07:21 PM) [snapback]233216[/snapback]</div>
    At one time the local high school had an ROP class in driveway-level mechanics. It cost only $25 a semester and lasted 2 hours every Wednesday. The first hour was classroom, while the last hour was shop. You had access to a two-post lift, hydraulic tools and even a 4-gas analyzer. Although it wasn't hooked up with the State, you could check to see if your car would pass smog before you went (it turned out my father's 1964 Studebaker polluted about as bad as a 1986 car). Those were the days. It would've been a snap to put the Prius up and do the install.
  12. Roger3125
    199
    Thanks
    Roger
  13. talonts
    talonts VFAQman
    468
    76
    <div class='quotetop'>QUOTE(Roger3125 @ Apr 4 2006, 01:08 AM) [snapback]234595[/snapback]</div>
    Roger,
    Please, do yourself a favor - do it yourself. You'll get the satisfaction of doing the work, and save money. Even if you have to buy the hex socket from an autoparts store/Sears/Lowes/Home Depot, you'll be ahead.
    Check with your local parts stores - Kragens and others loan out tools for free with a deposit, they're bound to have a torque wrench.
    As others have noted, no jack/jackstands needed. Just reach in from each side, 4 bolts and you're done.
  14. Catskillguy
    Catskillguy New Member
    536
    Mid Hudson Valley NY
    <div class='quotetop'>QUOTE(talonts @ Apr 12 2006, 05:40 PM) [snapback]238734[/snapback]</div>
    Ditto..
    A small cardboard box, 4-5 inches high the rest the new plate on while you tighten the bolts, would be a great help if you are doing it youself (suggested by another on an earlier thread).
