BT Streaming Question
Discussion in 'Gen 3 Prius Audio and Electronics' started by kmkremer, Oct 25, 2010.
  1. kmkremer
    kmkremer Member
    227
    30
    San Diego
    I recently had my JBL swapped out for the a new one as part of the TSB for weak FM reception. The new radio works much better. While my phone works fine (iphone 3G), the BT streaming doesn't work. I know that the dealer set this up for me when I originally picked up my car. I read the manual but can't seem to get it to work. Any help would be appreciated.
  2. jayvee
    jayvee Member
    341
    89
    WA
    The Phone and streaming are two separate pairings - you need to do both. See p. 295 of the Nav Owners Manual for Bluetooth Audio pairing instructions.
  3. Thai
    Thai Prius Neophyte
    1,197
    89
    There is a TSB?
  4. Joe166
    Joe166 New Member
    720
    96
    South Florida
    I had the same problem. It actually also lost all the AM and FM presets AFTER I had reset them and my contacts list when I got home from the dealership and after working perfectly on BT streaming, I was on a trip out of town and someone called me. The BT switched to the phone call, dropped the call and I had to pull over and reset the pairing for the IPod part of the phone. It acted up for a couple of days, forcing me to repair the connection a few times and then mysteriously fixed itself and has worked perfectly for the last couple of weeks. I have no idea what happened or how it fixed itself. Have faith and keep connecting it, it will probably fix itself. I had the manual open to that section for a few days until it stopped acting up. Keep it handy.
  5. jayvee
    jayvee Member
    341
    89
    WA
    One more often-missed setup that is required after battery disconnect (which was required for the swap) is to reset your NAV's "search area" to the correct geographical region. You set this through the DEST (search) menus, at the bottom of the search screens. It defaults to the east coast, I believe, so searching for a Subway near me (Seattle) always results in the closest one being 2500 miles away....:rolleyes: Long drive for a sub...
  6. jayvee
    jayvee Member
    341
    89
    WA
