Bug Removal - Blizzard Pearl
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jaihawk, Jun 3, 2013.
  1. Jaihawk
    Jaihawk Junior Member
    31
    Lincoln, NE
    Does anyone have a recommendation on a good car wash product for bug removal? I have a Blizzard Pearl Prius Four and just got back from quite a long road trip, taking out half of the mosquito population in North Central Nebraska by the looks of the front of my car. Previously, it seemed like the bugs were tough to scrub off by hand, so I tried taking it to a manual car wash and power spraying them off, but there's still quite a bit of stuff left for me to eventually wash by hand.
    I didn't know if there was a product that helped really break that type of stuff down.
    Thanks in advance!
    BobInSEFlorida likes this.
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I usually wait for a time when it's rained for several hours at least- it helps soften em up... then use one of those sponges with the quilted cover and regular car wash soap. The rain pre-soak is the most important step in the process- because the sun seems to bake them on pretty well. I actually go out when it's still raining to wash them off...
  3. Jaihawk
    31
    Lincoln, NE
    Do you do any kind of waxing once you're done that helps provide a little protective layer?
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    If you wash your car manually by hand, those bugs should come off. I have the Prius IV 2012 Blizzard Pearl as well. Killed many bugs going through Salinas and Marin, I wash them off with soap and use a long brush with hand scrub. Came off with no problem. rinse with water, wash with car soap, and dry it afterwards.
  5. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Look into Tarminator. I have used it on tar and it works very well. It's also supposed to work on bugs. Waxing the car should help future removal.
  6. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    Getting them off asap is most important. Bugs and bird crap will ruin the clearcoat. Best to keep a small bottle of water and a MF towel and a good cleaner handy. I use this just for quick cleaning of spots, Chemical Guys CWS_104_16 - Bug & Tar Heavy Duty Car Wash Shampoo
    PLSPUSH likes this.
  7. ny_rob
    1,968
    813
    L.I.- NY
    Nothing above and beyond the regular waxing- that's why I like to wait for a rainy day to remove the bug buildup- no damaging chemicals needed- just rainwater and regular car wash soap.
  8. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Some places, like where I live, don't get rain frequently enough to wait. Bug, tar remover usually removes wax as well, so follow with wax application. My humble opinion.
    SCH-R530M ? 2
  9. Indy John
    Indy John Member
    75
    33
    Indianapolis
    Haven't tried it, but one poster here a few weeks ago said to try a dryer softening sheet. Said it works like magic.
  10. CygnusX-1
    CygnusX-1 Junior Member
    Clay bar for bugs (after you wash the bug pieces off) and Zaino for polish. That works for me.
    Zaino Store
  11. Mike500
    Mike500 Senior Member
    2,593
    764
    I've had Simoniz "Glasscoat" on my "v" for 10 months, now.
    I didn't have it put on from the dealer with the outrageously expensive warranty, which is 60% of the cost and 20% goint to the dealer.
    While it states that it is not to be sold without the warranty, I bought a couple of bottles off of eBay.
    I have no problems "rubbing" the bugs off with a sponge and water with a carwash liquid.
    I'm sold on the stuff. But, $500 plus to too much.
    Glasscoat goes on extremely easy and levels easily with a micro fiber cloth.
  12. NutzAboutBolts
    1,476
    1,552
    Bay Area
    Zaino looks like a great product, it's also pretty expensive as well. Wish I had the money for it :(
  13. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Waxdirect.com. Sometimes sold at Sam's Club is also pretty good.
    SCH-R530M ? 2
  14. Hoosier1
    Hoosier1 Member
    87
    33
    Southwest Indiana
    Soak several large towels with water and spread them on the front of your Prius. After 15 minutes, the bugs will be easy to remove. This method will not damage your paint.
    A good product for bug removal is BugSlide. You can apply it to almost all surfaces, and it provides a protective coating that will not yellow or buildup.
  15. Jamesb93612
    Jamesb93612 Member
    133
    69
    Clovis, Ca
    I heard a tip from a private pilot that a bowl of water with dryer sheets soaked in it does wonders for bug removal. I tried it and have used it ever since! Super cheap and it does not harm the paint. Just let the dryer sheets soak in the water for a few mins then gently scrub away the bugs using the dryer sheets.
    iPad ? HD
    BobInSEFlorida and Jaihawk like this.
