Buick Intros 36 MPG Hybrid Sedan
Discussion in 'GM Hybrids and EVs' started by eheath, Mar 20, 2012.
  1. eheath
    eheath Member
    207
    New York
    2012 Buick LaCrosse eAssist Hybrid – Review
    By Jonathan Spira
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    I guess 25 mpg city did not make for a nice title ? :p
  3. smokiejoe
    smokiejoe Member
    178
    30
    PA
    eAssist is kind of Bogus. It does help a little bit on the Hwy. Doesn't help much at all in the City. Its a small alternator/motor which adds a few HP to the Engine via a Fan Belt at Highway Cruising Speed.
  4. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Mostly it makes stop-start and minor regen braking practical with fewer mods.
    Give them credit for the improvement over the conventional car.
    - Chris
  5. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    grade = D
    Selling a car that only delivers MPG in the low 30's should not be accepted as much of an effort to improve the typical consumer vehicle at a time when $4 gas is becoming common.
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    36 mpg US (43 mpg uk) is supposed to be good? Ha ha ha ha
    OK it's a step in the right direction but it isn't World class or ever class leading.
    As the teachers used to say on my report card "Must try harder" :)
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Or 29 mpg combined per Compare Side-by-Side.
  8. SageBrush
    11,627
    2,530
    Southwest Colorado
    I know squat about Buicks, but don't they tend to be large cars ? As others have said, the improvement over the non-hybridized model is quite nice. I wonder why it so much better than the pathetic improvement seen in the Malibu twins.
  9. eheath
    eheath Member
    207
    New York
    Did you read the article? Reason for improvement covered therein - in reasonably great detail! :cool:
  10. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It is a nice improvement. Although does anybody under 80 actually buy a Buick?
  11. SageBrush
    11,627
    2,530
    Southwest Colorado
    I skimmed the article, but did not read anything that explained the improvement. Help me out here.
    Honestly, this mild-assist system strikes me as nothing more (or less) than a stop-start solution. I do not know specifics of ICE off coasting, but in any case I doubt it came into play in EPA testing.
  12. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The MG has increased to 15hp from 5hp and the batteries are Lithium instead of NiMH. Improved transmission is a big one too. Also shutters on the grill, LRR tires, undercoating panels, and other little things.
  13. smokiejoe
    smokiejoe Member
    178
    30
    PA
    I guess it's better than nothing. I had read that there would be some stress on the Fan Belt since that is helping drive the Engine from the MG during cruising.
  14. SageBrush
    11,627
    2,530
    Southwest Colorado
    Which improvements are hybrid model only ?
  15. cwerdna
    12,544
    2,123
    SF Bay Area, CA
  16. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Based on a look I took under the hood of one of the original Saturn Vue hybrids it is much beefier than a standard serpentine belt, and the tensioning arrangement's different, since it has to be able to transmit torque in either direction.
    Assuming they sized things right, the belt could work out fine.
    - Chris
  17. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Around here they do ! :)
