Building 240v-250v battery to charge HV battery
Discussion in 'Prius PHEV Plug-In Modifications' started by kammssss, Aug 10, 2012.
  1. kammssss
    kammssss Member
    287
    86
    SoCal
    Hey Everyone,
    I've seen lithium prices drop significantly on ebay; so, has anyone thought of just building a 240v-250v battery (if I remember, someone said this the voltage needed to charge the HV battery) to directly charge the HV battery. I am trying to avoid the expensive converter.
  2. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    dave77 likes this.
  3. GasperG
    GasperG Senior Member
    1,168
    598
    Slovenia
    2018 Prius
    I also miss topics on converting gen 3 Prius, why would you stick with DC-DC convertor, safety reasons or something else?
  4. lopezjm2001
    1,146
    407
    Sydney Australia
    The battery ECU needs to be fooled. It is programmed to think that there is only a NIMh 6.5AH HV battery. The SOC becomes really low and starts the ICE to charge a HV battery that it thinks has a low SOC. Where in reality you have a 20ah lifepo4 battery connected in parallel. There is just no device available to fool the battery ECU for a Gen3. Possibly the design of the Gen3 makes it harder than generation 2.
    dave77 likes this.
  5. GasperG
    1,168
    598
    Slovenia
    2018 Prius
    Interesting, how does DC-DC converter fool SOC? With applying constant voltage? So building a higher voltage battery as OP stated wouldn't eliminate that?
  6. lopezjm2001
    1,146
    407
    Sydney Australia
    The converter is a trickle charger about 16 amps at most. Every now and then the battery ECU does a SoC check based on voltage and adjusts SoC accordingly so converter gets under the radar being such a small current. Even so there are still times the converter will cause a DTC. The Prius 2nd generation will allow a 16 amp discrepancy between the current measured by the battery ECU and that measured by the inverter. If discrepancy in current exceeds 16 amps a DTC is usually thrown.
    The converter is connected so that the current is seen by the battery ECU going into the OEM HV battery. As instructed by Enginer.
    A second Lifepo4 HV battery is connected in parallel with the OEM HV battery and therefor current cannot be seen by the OEM battery ECU going into the OEM HV battery.
    dave77 likes this.
