bumby when accelerating from 0
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Esa, Nov 15, 2018.
  1. Esa
    Esa New Member
    Ireland
    I have a 2010 Prius with about 160000km on it. I noticed that, when I start accelerating from traffic light for example, the car is bumby, this settles down when I get a little bit of speed like 5 - 10km/h.
    Any advice what could be causing this?
  2. Esa
    Esa New Member
    Ireland
    Just to add, there are no error codes or alerts in the display
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Please define "bumby".
    If that means bumpy or jerky, you might need some transmission service.
    Could be a wheel bearing or CV joint too.
    Could be the gas engine running a bit rough when it first starts up.
    An inspection by a qualified shop should be able to tell the cause.
    It is normal to detect a very slight bump when the gas engine cuts on after leaving a stop.......with some models and some people.
    Some people don't notice it at all.
  4. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Sounds normal
  5. bisco
    49,504
    welcome!
    have you cleaned the egr circuit? do you have egr in europe?
    Raytheeagle likes this.
  6. milkman44
    milkman44 Active Member
    591
    386
    Ky
    How about using the Power setting, less lag for engine to start.
  7. Esa
    Esa New Member
    Ireland
    Interesting thing about this, I also noticed that the car was running low on coolant. After adding coolant to it, and let it run for a while with the coolant cap open, I have not felt the bumpiness anymore. The define the "bumby" a little better, it was like driving on ribbles on road.
