Bumper "Plugs"?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by qdllc, Aug 15, 2016.
  1. qdllc
    qdllc Senior Member
    1,370
    399
    When I was washing the Prius yesterday, I noticed the front licence plate bracket coming away from the bumper. In short, there was a minor "ding" a year or so ago, and the bumper was removed and repainted by Toyota. Whether the mechanic did it or it was a result of the "ding" one of the self-tapping screws used to put the bracket onto the bumper had stripped out and was barely holding it on the car.
    Ultimately, I solved the problem by finding a matching set of self-tapping screws that were a larger diameter to created bigger non-stripped holes in the bumper. Still, if this happened again, I'd not want to keep going larger.
    Is there a "plug" that can be inserted into a pre-drilled hole to create a refurbished anchor point for the bracket if it happens again. Ideally, if I moved some place that doesn't require a front license plate, they could be color matched to blend into the bumper to there aren't two holes in it.
  2. Mendel Leisk
    38,726
    You got me surfing; there's lots of DIY ideas, painting a plain fastener, and a prepainted, somewhat pricey option:
    BumperPlugs for Toyota
  3. JC91006
    16,482
    8,400
    The what if question, man that is a time consuming topic
  4. Mendel Leisk
    38,726
    Yeah, the essence of cargo cult: preparing for something, that's never coming.
  5. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Just use a standard screw plug, the ones you insert into drywall etc. They expand enough to hold a license plate.
  6. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    License plate bolt kits at every car parts store....some with backing bolts some without. Sounds like you need backing bolts.
  7. mikefocke
    3,699
    1,645
    Sanford, NC
    I used bumperplugs.com to get some bumper attachments for a silver Porsche. (silver is hard to match.) Wonderful people to deal with, perfect match, still perfect after 6 years.
  8. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    I sometimes ponder at the meaning of life...
