Burned Out Dash Lights
Discussion in 'Generation 1 Prius Discussion' started by mlibanio, Feb 7, 2011.
  1. mlibanio
    mlibanio Member
    304
    60
    Toronto
    2002 Prius
    I
    Hi everyone, I am having a problem that has been cropping up the last two weeks or so. Steadily, several bulbs on my dash have been popping, but it is very strange as the pictures will attest. Does anyone have any idea if these are hard wired bulbs or can they be replaced? Right now its -10 C in Toronto, so I don't want to pull apart the dash unless I know for sure they are replaceable. You would figure the number of times I have taken it apart I would have noticed, but any idea's are appreciated. Thanks everyone.
  2. macmaster05
    macmaster05 Senor Member
    4,020
    709
    Wow. Is that the new Prius? That dash looks better. Much improved over the 2010!
  3. mlibanio
    mlibanio Member
    304
    60
    Toronto
    2002 Prius
    I
    Nope that is the first Gen Prius. I upgraded the nav on my prius to the Generation 4 unit found on the Generation II Prius'. It was totally plug and play. The resolution is so sharp its amazing. Thanks for noticing!
  4. ChapmanF
    7,429
    From the time I had mine apart I believe they are. I'm not sure how easy they are to get from anywhere but the dealer. I'd be tempted to replace them with LEDs just for the fun of it, but probably hard to get a uniform appearance unless changing them all at once.
    -Chap
  5. ea8631
    ea8631 Member
    185
    74
    Toronto, Ontario
    Technology
    Yup, they are replaceable, I just replaced mine (x2) before winter. They cost around $5 or $6 each from dealer. From the picture you attached, I think you need 5 bulbs.
  6. mlibanio
    mlibanio Member
    304
    60
    Toronto
    2002 Prius
    I
    Hi Joe,
    long time no see, we should get together again if you are in Toronto! At any rate, do you know which bulbs I should ask for at Toyota? Thanks a lot pal. Nice to hear from you again! How many kms does your little blue prius have now? Must be over 400,000 now!
  7. ea8631
    ea8631 Member
    185
    74
    Toronto, Ontario
    Technology
    Hey mlibanio how are you? I know the parts you looking for since
    I did replace mine before winter. I will try to find the parts number and let you know once I find it. My prius still doing fine, but I didn't drive as much as use to be. Therefore it only have 386000km on it. Let me know if you need anything more or give me a call since I lost my contact list .
  8. ea8631
    ea8631 Member
    185
    74
    Toronto, Ontario
    Technology
    sorry for the late reply. the bulb part number is 90010-01039.
  9. srponies
    srponies New Member
    WI
    2001 Prius
    Question regarding the replacement bulbs - do they come with the green coating/covers on them? My bulbs need replacement too, and I found they have green covers to tint the lighting.
    Thanks,
    Steve
  10. ea8631
    ea8631 Member
    185
    74
    Toronto, Ontario
    Technology
    Yes, the replacement bulb do come with the green rubber cover.
  11. Classic_pri
    Classic_pri Former 2001 Prius 0wner
    Wisconsin
    To do them all, you need seven. I know that because I went into the project with six!
    If you've had the center stack fascia off before, you shouldn't have too much trouble. The trick is to get the assembly out of the dash far enough so you can get at the screws holding the fascia panel to the metal framework.
    Those who are tackling the project for the first time should be aware that the plastic panel can get brittle with 10 years of aging. If it breaks, a new one is about $150 (btdt).
  12. Kutanks
    Kutanks Member
    118
    MA
    This seems to be a problem typical of many toyota vehicles. two of my friends drive 2nd gen ES300s with burnt out clusters and the cluster in my 2001 sienna was also burnt out. What gives?
  13. ChapmanF
    7,429
    You might have to plan to replace some light bulbs every decade or so?
    -Chap
    Hipstor likes this.
  14. mygjob
    mygjob Junior Member
    Yadkinville,NC
    2002 Prius
    Thanks to all of you who have posted info about how to replace burned out center dash lights. I just finished replacing the bulbs in my newly purchased 2002 prius last night. Removing the center bezel was very difficult! Had it not been for Priuschat, I certainly would have busted the bezel into several parts. Because of all the postings, I knew to be really careful! I knew to remove the emergency flasher and remove the two nuts below the display, slide the whole unit out a little bit, and look for the screws that hold the bezel. I found 4 screws that were not mentioned in either of my repair manuals. Two were on each side of the radio and two were just inboard of the air vents. It took me a long time to remove those screws! After that, unplug the wires, manually release the shifter, and it was out in one piece. Hooray! The bulb swap was simple. It went back together much easier. I did NOT reinstall the four screws. I am much happier now, because my prius has a beautiful green glow at night! Many, many, many thanks to all who post on Prius chat!
    DDR likes this.
  15. ejcabotaje9
    ejcabotaje9 Junior Member
    30
    Riverside
    2002 Prius
    Wow that's a great looking nav. Does it have the same function as the original screen (like it shows the energy flow and all that stuff?) It looks like it came from a Lexus or something.I want to do the same for my car as a project, but i don't know which generation prius screen will fit for my 2002. I know you mentioned generation 4, but which year did you get it from?
  16. mlibanio
    mlibanio Member
    304
    60
    Toronto
    2002 Prius
    I
    Hi there, the screen is actually exactly the same. If you Prius does not have a factory navigation system, it is possible to install, and I have documented it on Prius chat for any member that wants to try. The Generation 4 Navigation system is the same unit found in the 2004-2006 Prius. I had installed the Generation 3 unit which is vastly inferior. The resolution and logic is much better on our screens, and for some strange reason looks better, though smaller than the screens on the Gen 2 Prius. Go figure. Anyway, the Energy Flow screens and radio are all still there. It just looks really cool. My favourite is the Toyota iPod kit, where I can see Song Titles and Artist on the Screen, now that is cool, even though Toyota says it will not work on our cars! Look for me in about two months time. I have imported the Video In Cable from Japan, and will be installing it soon, so we can watch TV or even put in a back up camera and it will show up on the screen. It was straight from Toyota in Japan! Totally Plug and Play and no wire cutting required. I can't wait.
    ejcabotaje9 likes this.
  17. Thadd Dale
    Thadd Dale New Member
    can you tell me what you had to do to install it?
  18. mlibanio
    mlibanio Member
    304
    60
    Toronto
    2002 Prius
    I
    Look up my threads on the navigation install. The 2004 Prius will actually be quite similar, but you will need to get a different dash top to accomodate the Navigation related buttons. This alone makes it very costly above and beyond just the NAV ECU and wiring. I can assure you though, it is a good system, but the Gen 4 Navigation ECU simply lacks the sophistication of other units. My Chrysler Neon's factory navigation is miles better, and will always find a significantly better and more efficient route. However, if you want to go ahead with the install, I am more than happy to help. I have helped about 7 people all told, and one Gen 2 Prius owner who braved it and did it.
  19. ChapmanF
    7,429
    I'm not sure if I'm just lucky, or the plastic really gets a lot worse in a panel much older than mine, or if the way it's done can make much difference, but I did shoot this video back in August and just now got around to editing it for a hosting service, in the hope maybe it can save someone some aggravation.
    (In case the video embed feature in the forum software gives trouble, here's a direct link.)
    -Chap
    #19 ChapmanF, Nov 22, 2014
    Hipstor and mehanson like this.
  20. ger-ev
    ger-ev New Member
    Hungary
    2001 Prius
    Hello there, I have successfully changed the light bulbs.
    EU model
    I used third party bulbs ordered from conrad.de
    bulb data: T1 socket 2.3mmx6.3mm, 12V 60mA
    (i measured amps of a good one)
    type: barthelme: 60 mA 0,72 W 21109126 369969
    You can replace the bulb in the white round mounting.
    The green cap is made of some silicon material, it can be removed from the original.
    My experience:
    1. Be careful with removing center console, fragile plastic! Watch the previos great video about that!
    My addition to it is:
    if you open the glove box, you can reach the two clips on the right from back and push out by hand.
    if you remove the plate under the steering wheel, you can reach the two clips on the left.
    It takes much less stress to the plactic frame.
    2. a bit hard to remove the round bulb holder because of deformation by heat. I used a scalpel to grab.
    3. you need 7 pieces or 8 if you want to replace the hazard light button bulb (it is the same but without green cap)
    Fog light and headlight height adjustment button is having a 50mA bulb with 3.2x7mm size.
    can be ordered from conrad.
    #20 ger-ev, Feb 26, 2017
    Hipstor and Brian in Tucson like this.
Loading...
