Burning 3.9qts every 1000 miles
Discussion in 'Gen 2 Prius Main Forum' started by Fatmatt86, Dec 5, 2018.
  1. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    My vehicle is a 2007 Prius Base and burns oil like crazy. It currently has 241,942 miles on it. Original engine and everything. It does not leak. A UV test has been performed and no signs what's over oil in parking space/garage. I have been keeping a record of oil changes viewed here below. I have changed spark plugs, all 4 coil packs, the Oil Control Valve OCV, as well as the PCV valve, and still oil seems to burn. It might be good to note that when I write out of oil below, I'm referring to the first red triangle of death that appears and the word Problem comes on the screen. If not noted below, every oil change was 5W30
    225,839 oil change at Tilden
    225,884 changed spark plugs and PCV Valve
    227,033 out of oil
    227,094 added 4 quarts of super tech full synthetic oil
    228,156 out of oil
    228,223 added 1qt super tech full synthetic oil
    228,533 out of oil
    228,536 added 1qt of QT oil
    228,811 Out of oil
    228,813 added synthetic oil from 7-Eleven
    229,740 oil change and tire rotation at Tilden on Alta mere
    230,833 out of oil
    230,833 added 5w-30 pro oil
    232,153 out of oil
    232,171 added 1qt of 10w30 fuel city oil
    232,488 out of oil
    232,501added 1 qt of Pennzoil 5w30
    232,842 out of oil
    232,887 added 1qt pro line 5w30
    233,263 out of oil
    233,285 oil change Tilden LVT
    234,347 out of oil
    234,363 added 4qt of Pennzoil
    High milage oil 5w30
    235,507 out of oil
    235,633 added 2qts high mileage
    236067 out of oil
    236084 added 1qt
    236448 oil flush and oil change at Tilden. Suggested oil control valve for oil burning fix.
    236804 replaced OCV
    237700 out of oil
    237770 added 4qt of full synthetic
    239173 added 1qt dg plus
    239397 out of oil
    239477 added 1qt dg plus
    239800 out of oil
    239804 added 1qt dg plus
    240000 out of oil
    240006 added 1qt dg plus
    240346 out of oil
    240349 added 1qt quick trip
    240702 out of oil
    240715 added 1qt Pennzoil 5w30
    241060 out of oil
    241300 oil change at Napa Alta mere
    m.wynn likes this.
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Your running the car until the light comes on for low oil? Start looking for a new engine if you are. The one you have won’t last much longer.
    douglasjre, edthefox5 and Raytheeagle like this.
  3. PriusCamper
    PriusCamper Senior Member
    12,796
    5,180
    Pacific Northwest, USA
    Any visible smoke?
    Is the engine cleaned regularly so you can identify the location of leaks?
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Yeah, I'd say that engine is pretty shot. The catalytic converter will soon be shot, too having to deal with that much oil. When the oil light comes on, that because it lost pressure. It lost pressure because it was sucking air. Air is not a good lubricant. Hence the engine damage.
    But hey! 242,000 miles is a good, long run. I think you got your money's worth out of that buggy.
    theory816 and dubit like this.
  5. PriusCamper
    12,796
    5,180
    Or maybe it's just an oil pan gasket or something? Of course, you'd think OP would notice that much oil on the ground in the car's primary parking spot?
  6. frodoz737
    frodoz737 Top Wrench
    4,702
    2,501
    33
    If you are looking for an excuse to buy another car...you got it.
    #6 frodoz737, Dec 5, 2018
  7. jerrymildred
    11,517
    14,152
    Tampa, FL
    That would be nice, but I'd think he would not have said there was no oil on his parking place. He'd have an awful mess if it was leaking that much. And, if it was leaking higher up, the engine bay would be a mess, too.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    THIS.
    And did you REALLY think that any of those parts you changed would have ANY impact on high oil usage ???
    If so, you got some really BAD advice.
    At this point, you don't need synthetic oil; just a waste of money.
    A complete change to a high mileage 10W40 or 20W50 and then checking it EVERY DAY might get you a couple more thousand miles.
    But you need to face the reality that this engine is just about gone.
  9. Skibob
    2,912
    1,505
    Northern California
    After running the car out of oil 19 times I’m impressed the engine still runs. Nothing is going to save that motor at this point. Drive over to the the engine exchange place, or the Junkyard while the engine still runs would be my advice.
  10. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    Agree with others; engine is in really bad shape. When these engines burn oil it's usually worn piston rings. If you run low on oil a few times, it usually gets much worse. I would switch up to 20W-50 and run a couple of tanks of fuel cleaner while you look for a new car, both of which will help a bit with the oil use (fuel cleaner can remove a bit of gunk from piston walls/rings and often helps). Otherwise, you're likely to have a total engine failure shortly, and for sure the catalytic converter will go soon with how much burnt oil is going through it. Sorry for the bad news. 241K is still a really good run for a car.
    macondo100 and jerrymildred like this.
  11. ETC(SS)
    7,184
    I'll bet that people behind you just LOVE the smell.
    +1 with the new engine.
    I'd start buying Wallmart 20w50 by the case (it'll be a third of the price of that Gucci oil that you're putting in there now!) and then I'd shop for a new G2 - keeping your present G2 for spare parts.
    Since it's a 12-year-old car with Lunar Mileage, I'd find a low mileage G2 rather than stuff a used engine and new cat into this one.
    Good Luck!
    M in KC and Skibob like this.
  12. KevininFl
    KevininFl Junior Member
    61
    16
    Fort Myers Fl.
    Try Motul 5-30 and Motokote on your next oil change.
    m.wynn likes this.
  13. bisco
    52,001
    call toyota customer service and ask for good will warranty coverage
  14. davecook89t
    davecook89t Senior Member
    1,089
    825
    Washington State, Florida
    Four Touring
    :ROFLMAO:
    Prius Rising, AzWxGuy, Skibob and 2 others like this.
  15. sam spade 2
    7,035
    2,803
    2017 Prius c
    Since it is kind of hard to determine that the engine really is completely "out of oil" (without removing the drain plug to see if anything comes out).......I suspect that his "out of oil" wasn't completely accurate.
    In most cases I've seen or heard about, if the engine really does run completely out of oil, it will overheat and melt down.....literally.....pretty quickly. Like in the time it takes to slow down and pull off the road.
    Fatmatt86 likes this.
  16. fuzzy1
    10,483
    (1) Are each of these 'out of oil' events verified as no oil visible on the dipstick?
    (2) I'm seeing lots of 'out of oil' events followed by adding just a single quart. But if really low enough for such a warning, shouldn't it take a lot more than a single quart? By not fully refilling, it seems that this engine as been run low or out even more than necessary.
    But at this point, this may just be questioning a well beaten and long dead horse ...
  17. frodoz737
    4,702
    2,501
    33
    Dip stick shows empty at 3-1/2 liters low...with one liter remaining if you are lucky. I found out first hand when the dealership left my filter bowl loose "once" on my now retired 2010 Prius. 19 times as described...motor's shot Fatmatt86. Sorry.
  18. padroo
    padroo Senior Member
    2,763
    2,252
    Time for a new car.
  19. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Run thicker oil and run your car until it spontaneously combusts ending in scorched earth. In the meantime start your search for a new mill or new whip.
  20. bisco
    52,001
    run some kerosene through her
