Burning oil/needs new hybrid battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Spiral80, Feb 7, 2025.
  1. Spiral80
    Spiral80 New Member
    Nevada City
    Four Touring
    Hello!
    I’m new here and looking for advice.
    I have a 2008 Prius that I bought used at 78k miles. It’s now at 175k miles, needs a new hybrid battery and is burning about 1 quart of oil every 2k miles.
    The mechanic I’ve been taking it to for all the scheduled maintenance advised I think about replacing the car rather than spending the money on replacing the battery because the burning oil indicates the catalytic converter might not last much longer and is expensive to replace.
    I’m considering replacing my car with one that better suits my current needs (awd) but I don’t want to do that unnecessarily if there might still be a lot of life left in my Prius once it has a new battery.
    If anyone has any insights around this and can offer any advice I would greatly appreciate it!
  2. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Bad advice from mechanic...
    A quart of oil lost every 2K miles is close to normal for a car with 175K miles...
    As for catalytic converter, yes OEM ones are very expensive, but if your cat fails an aftermarket one costs less than $100 so it's not going to be an issue.
    Moresnow likes this.
  3. pasadena_commut
    pasadena_commut Senior Member
    2,282
    679
    Southern California
    Unless you live in California. CARB has to approve the replacement CCs, which makes them expensive.
    Toyota Prius CARB Catalytic Converters | MagnaFlow
  4. Spiral80
    Spiral80 New Member
    Nevada City
    Four Touring
    Thanks for your reply. Is there anyway to assess how much more life I might have on the catalytic converter?
    Also a local express lube where I get my oil changed recommended an engine flush. I looked it up and it seemed like it could help so I went for it. I may have noticed some improvement but I don’t have an exact measure so it’s hard to say for sure. Is this something you would recommend on a semi-regular basis or not at all? Why or why not?
    And in response to pasadena-I do live in California so thanks for the heads up on that.
  5. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    ... or a state that adheres to CARB standards.
  6. douglasjre
    douglasjre Senior Member
    2,097
    701
    Null, NL
  7. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
    @Spiral80 Almost anything can be repaired and maintained...with cost and effort. Only you can decide if and why you want to start throwing big money at an old car. For everyone else...Nevada City is in CA.
  8. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    Not sure what is the issue with the battery. Depending on use they can last for a long time. If you do a lot of high speed or hilly driving and the battery gets to the bottom of the scale on the display, how long does it take to recover to the top third of the picture? How many bars does it typically show on start up? Regardless, rebuilt packs are about 700 bucks installed and will last for a few years. Mine is on year 6 and has no issues.
  9. pasadena_commut
    2,282
    679
    Southern California
    That was my point. Well, it could be the one in Montana, but I doubt it A mechanic in Montana would have told the OP not to worry if the cat fails because they can just bolt on an aftermarket, which isn't expensive, or (looks around to be sure they were alone), just put in a straight pipe (you didn't hear that here) because there are no inspections.
  10. dolj
    dolj Senior Member
    8,217
    4,187
    This may be true for you, but as time goes on and the used battery stock becomes older and weaker, it will be less true for others.
    This one where mileage does vary and the variables are many.
  11. pasadena_commut
    2,282
    679
    Southern California
    There are two things going on. The first is that the oldest available modules are now very old, one really wouldn't want a pack made with a 2004 module regardless of how it was reconditioned. The second is that there will be modules entering the rebuild pool from packs which were replaced fairly recently. Are there manufacturing date stamps on the modules themselves? If so, seems like the purchaser of a reconditioned pack would want a list of those. I have never bought a reconditioned pack for this vehicle, perhaps they already supply that?
  12. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,894
    Texas Hill Country
    Good advice from your Cali mechanic...
    I would get something that meets your current needs. The Prius has resale value as is; waiting for the big repair is a bad time to sell.
    Your car is 17 years old. In addition to a hybrid battery, oil burning will eventually take out the cat (unless it is stolen first), brake boosters fail, coolant heat storage systems act up and routine maintenance costs accumulate.
  13. PriusCamper
    12,064
    4,896
    I've spent too much time with battery rebuilders who have spent tens of thousands in lab-grade testing gear and decades of experience to agree with you. The age of a battery module doesn't define its lifespan, it's use over time defines its lifespan.
    What's more, basic scientific knowledge of NiMH chemistry and its need for periodic reconditioning to maximize its lifespan is something Toyota eliminated entirely in order to generate more revenue and create a massive amount of fraud and waste.
    They are lying about packs needing to be replaced about 70% of time. When it comes to actual materials' science, corrupt and greedy corporations are very much anti-science. Even the general check engine light for all issues with hybrid battery has a description that is often a lie: P0A80 - Replace Hybrid/ev Battery Pack. All you could have is corrosion or a bad wire and the Toyota Stealership will insist you have to pay $4K on a new pack before they even do further diagnosis, they just point to what the error code says and that's how to fix the problem.
    It's been demonstrated on here countless times, the stealership just shrug their shoulders and says more expensive stuff needs to be replaced AFTER customer drops $4K on a pack and it doesn't solve the problem.
    Think of how many low income people who have had their lives ruined and lost the only car they could afford to put gas in because of this level of corruption at Toyota?
    #13 PriusCamper, Feb 9, 2025
  14. rjparker
    9,597
    5,894
    Texas Hill Country
    I rest my case
  15. pasadena_commut
    2,282
    679
    Southern California
    Sure, but there is simply no way the purchaser of a refurbed pack can determine the latter value for a module. Not even the people putting together a commercial refurb pack will generally have any information on that. If the modules have date stamps then at least in theory that information can be shown to the purchaser who can use it as a proxy for the other unknowable value.
    #15 pasadena_commut, Feb 10, 2025
  16. PriusCamper
    12,064
    4,896
    The rebuilders offering 3 to 4 year warranties and not going broke doing so are the ones who can tell us way more about a modules history than we thought possible. Also, the big companies offering lifetime warranties, have similar abilities, but they've proven to end up going broke and getting bought out, like GreenBean for example.
  17. uart
    uart Senior Member
    4,220
    1,209
    Australia
    How much is it for a new (not reconditioned) HV battery in your area Spiral. From what I've read it should be about $2k or a bit more, is that correct.
    If you've owned the car for a long time and it's in otherwise good condition I'd consider getting a new battery. One quart oil per 2k miles is not that much and mine (currently at 280k miles) never increased much past that in the last 120k miles anyway. That's equiv to 300mL per 1000 km, which is roughly what mine has been consuming for years now without any great increase. Yours could easily go another 100k miles plus without oil consumption being a big issue, just make sure you keep the oil up to it and use a good robust oil. I find oil with an "ACEA A3/B4" rating gives me lower oil usage compared to more the 'fuel economy" rated oils like ILSAC GF5 etc.
    BTW. I put a new (from Toyota) battery in mine at about 300,000 km, and oil consumption was similar to yours at the time. That car is still going strong at 462,000 km and I've never regretted buying the new HV battery for it.
