Burning sensation on tongue
Discussion in 'Prius v Main Forum' started by vss0253, May 24, 2022.
  1. vss0253
    vss0253 New Member
    greenbelt,MD
    2015 Prius v wagon
    I have 2015 Prius v3 and recently changed water pump on it. 2 weeks before car started giving low gas mileage and there was burning sensation and tongue tingles after 5 minutes of driving. No smell of fuel in the car. Gas mileage has improved after 2 days of changing water pump but that burning sensation on tongue and mouth has gotten worse. Should I get some CO fumes detector. Please suggest any remedies.
    Thanks
  2. ChapmanF
    15,622
    This is a story I haven't encountered before, but if you have any concerns about possible CO in the cabin, getting a good CO detector (ideally the kind with a ppm display, not just a honker) is cheap, and probably the only way that you will either confirm the issue or set your mind at rest.
  3. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    This sounds more electrical in origin than combustion/CO, but agree with the need to get it to ground, quickly. A CO 'dot' in the cabin will tell the story.
  4. Air_Boss
    3,952
    1,083
    New Yawk
  5. bisco
    49,494
    are those symptoms of co poisoning? you should call your doc, might be anything.
  6. rjparker
    rjparker Tu Humilde Sirviente
    7,977
    4,717
    Texas Hill Country
    Open the windows and drive. If present, CO will be eliminated with air dilution. The same test works for refrigerant (freon) leaks. Electric usually has that typical burning smell most have experienced.
    Tongue tingling is usually low blood sugar, low calcium levels or anxiety.
    Tim Jones likes this.
  7. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Might be the anxiety of driving a car that could BLOW UP at anytime.......
  8. bisco
    49,494
    BLOWN UP??? you said my parents died in a car crash (n)
    #8 bisco, May 25, 2022
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,918
    Columbia, SC
    Also been known to be an effect of battery acid/vapor or engine coolant/vapor. One reason I don't do the 'taste test' of car fluids. Always shake my head when I see people do the sniff and lick test....on car stuff...
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    At the risk of stating what should be obvious:
    SEE A DOCTOR.
    :eek:
  11. bisco
    49,494
    symptom of coolant after a water pump change?
  12. Air_Boss
    3,952
    1,083
    New Yawk
    Have you had a recent COVID test?
  13. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    "It could be a tumor"...
    "IT'S NOT A TUMOR (in thick Austrian accent)"
    dig4dirt and Tim Jones like this.
  14. sam spade 2
    7,035
    2,788
    2017 Prius c
    OK. So it could be Syphilis. :eek:
