burning smell uphill?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ericspoor, Mar 11, 2019.
  1. ericspoor
    ericspoor Member
    76
    37
    austin
    Theres one hill on the way to my friends place that quite steep/long, and when i go up it i get a burning smell from the engine bay- would that be the transmission? If i've burnt some of the trans fluid should I attempt to add more? fluid was changed 8k miles ago with 4 qt's toyota atf.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Probably lost the inverter coolant pump. Put the car in ready and open the Black Cap on the inverter coolant reservoir and with a flashlight look inside the fluid should look like it’s boiling reflecting good coolant flow,
    Or the engine is very low on oil. Both of these require opening the hood though.
  3. Mendel Leisk
    41,889
    On cars in the past I've got smells after a hill-climb (well a mountain climb) that were likely from undercoat that sprayed onto the exhaust. Still, @edthefox5 's suggestions are more serious, should be checked first.
  4. ericspoor
    ericspoor Member
    76
    37
    austin
    Ill have to do the inverter pump check after work, should be good im thinking but will confirm/deny. The inverter pump was replaced w/oem by matt at texas hybrid batteries 8k miles ago. (backstory on car- purchased on craigslist 6mo ago for 2k with 242k miles and hv battery replaced with oem in 2011. Changed spark plugs/air filter/cabin air filter then drove it to texas hybrid batteries where matt replaced the inverter pump/inverter coolant/engine coolant/transaxle fluid/cleaned maf sensor. Cant recommend texas hybrid batteries enough!)
    Im pretty good about checking the oil level, i change it with mobil 1 every 2000-2500 miles in the 8k ive had it+ check every two weeks to see wheres it at on the dipstick- lowest ive seen it was inbetween the dots. That said, if the oil level was imbetween the dots when bombing up a steep hill perhaps that couldve caused it? (I have to get up to 80mph before i hit the incline then i let internia take me up the incline as much as it can then get back on the gas when the car starts to slow down. Probably eek over the top of the hill at 40mph.)
  5. padroo
    padroo Senior Member
    2,763
    2,252
    All fluids should be checked and monitored until you find the source of the problem.
    Have you ever checked the coolant by removing the radiator cap instead of just the overflow tank?
  6. ericspoor
    ericspoor Member
    76
    37
    austin
    Just drove up the hill in question and got tge burning smell again. I want to say it smells electrical but idk. Its only occurring on this particularly steep hill. I checked the oil and its near full, and the inverter pump is giving turbulence. One thing i noticed is the inverter coolant level ia right at the low mark. However, the full mark doesnt seem mich higher at all so not sure if that is a factor
  7. ericspoor
    ericspoor Member
    76
    37
    austin
    another piece of info: i went up the same hill again but this time in traffic, start-stop. no burning smell. seems like its only when at speed going up the hill.
  8. JirkaV
    JirkaV JirkaV
    Prague, Czech Republic
    So I was crossing a major hill (Alps in Europe) at high speed (about 80mph) and got burning smell too. Not noticeable when driving, but when we stopped right after a long fast uphill drive, the A/C pulled the smell in and it made a noticeable light fog inside. Gone away in a few moments after we rolled down the windows. I walked around the car and didn't notice anything odd when outside.
    Had the car checked at authorized Toyota dealer and they found nothing wrong with the car. It might have been just some vax or other residues burning off when ICE got really hot as it normally does not have to work that hard.
    Wanted to post here in case someone was searching for the same problem.
  9. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Pretty common story.
    Hybrid battery not supplying anywhere near the current it used to from old age so all the power capability falls to the tiny little 90 horsepower motor and you have to basically floor it to get up any substantial hill. Didn't you hear the motor screaming for dear life? You never once looked at the battery meter on the mfd if you did you would have seen the battery was in purple.
    So that low power low volt HIGH LOAD really stresses out the trans and the inverter and is the best possible way to destroy the transmission. That super current draw across the motor windings is a guaranteed winding blow out..
    This is a very under powered car all the torque comes from the hybrid battery.
    Seen many clueless posters on this site over the years with the car stuck on the side of a mountain in severe overheat. Same story. Old worn out hybrid battery car full of people or load and then they expect to be able to run up the hill effortlessly. Engine screaming all the way.
    What your smelling is the trans fluid and Inverter cooolant boiling. if you opened the hood you would have seen that. The only thing that saved you was its winter.
    if I was you I would change all the fluids and oil. Pull the trans fluid I bet it smells burnt.
  10. JirkaV
    JirkaV JirkaV
    Thanks for the reply! My apologies, I should have been more specific as this is an old thread I found by googling and did not notice it was a Gen2 forum. I was driving Prius PHV (a.k.a. Prime). So the battery meter was not showing purple. In fact, the battery was nearly full at that point. Also - it definitely wasn't an "old" battery. The car is less than 18 months old.
    I had the car at dealership after the event (it just happened it hit the regular service interval). The hybrid system was checked and found in perfect condition.
