Burning Smell
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gfshay, Mar 10, 2009.
  1. gfshay
    gfshay New Member
    ca
    I have 52,ooo miles on my 2006 Prius. It gets 46-50 mpg depending on driving. Last week had a smell of burning. It smelled like a plastic bag got caught on the tailpipe or when you drop oil on the hot engine. I stopped car, looked under hood and found no smell and nothing boiling over. All fluids were full. Last oil change and checkup at 49000 or so. The smell went away and now one week later came back. Both times were when going up a hill. Any suggestions except the obvious?
  2. magruder
    magruder Average Member
    145
    Colorado
    So you smell the burning inside the car, but not under the hood? It only happens under load though. It seems like you would have to be able to smell it under the hood. I assume your car doesn't drip any oil on the ground. Nope sorry can't help. Patrick where are you?
  3. richard schumacher
    7,663
    1,038
    United States
    Was that the first time you drove up a hill that high/long? It may be that the battery control system had never been used that hard before, and it got hot enough to cause some plastic to outgas. That would be normal.
    Make certain that the battery cooling vent to the right of the rear seat is never blocked in any way.
  4. gfshay
    gfshay New Member
    ca
    thank you
  5. Patrick Wong
    18,200
    6,472
    Is the cabin heater on? Maybe the two PTC electric heaters are producing the smell after a period of disuse.
    If you continue to smell this unusual odor, I'd suggest raising up the car sufficiently so that you can look at the entire exhaust system to see if any debris is caught up. If no debris, then look at the engine and transaxle to see if there's a leak where oil can drip onto the exhaust.
  6. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    One windy day, I managed to run over a black plastic garbage bag - empty - that was blowing around. Gawd did that ever start to stink, it melted itself to the catalytic converter
    I ended up putting the car on my large ramp at my hobby farm, and using a gasket scraper to scrape all the residue off the catalytic converter.
