Buy it or Pass, 2017 Prime with 6000 miles?
Discussion in 'Prime Main Forum (2017-2022)' started by philr, Sep 23, 2023.
  1. philr
    philr Junior Member
    north carolina
    A family member has offered me their 6000 mile, 2017 Prime. It looks like new but what about the drive battery and electronics? What is a safe price to purchase this vehicle?
    Thank you
    Phil
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    I would not worry about the drive battery or electronics at all. I mean, I would make sure it will take a charge and run in EV at least 20+ miles. About the only thing that could be an issue is the 12V (aux) battery. Unless it has been kept on a tender, it may be degraded and not hold a good charge. A mechanic could do a load test to be sure. The other thing I would say is perhaps the gas has gone stale. I would put fresh gas in and run the gas motor (HV and/or CHG mode) maybe 500 miles or so to make sure the gas portion of the synergy drive is tested and fresh gas is circulated around the system. As far as price, you’re looking at a unicorn with those miles, so expect to pay a premium for such low miles.
    52,838
    I’d buy it in a heartbeat if the price is right
    PT Guy and JohnPrius3005 like this.
  4. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    Kelly Blue Book is always a consensus tool.
    JohnPrius3005 likes this.
  5. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Buy it. There is no “safe” price, just average wholesale and retail prices. Price is whatever you and the seller are happy with. Family member means you are not paying a stupid profit to a dealer who adds nothing of value.
  6. ColoradoBoo
    ColoradoBoo Senior Member
    1,348
    972
    Monument, Colorado USA
    We have a 2017 and have had zero issues. Did you mean to say 60,000 miles instead of 6000? Ask them how often they changed the oil...hopefully every 5,000 miles. It's now over 5 years old so will need transmission and coolant changed out. (Spark plugs are good for 10-years or 100,000 miles, whichever comes first.) And, it it hasn't had them cleaned, the MAF sensor and Throttle Body could use a cleaning.
  7. Washingtonian
    Washingtonian Senior Member
    726
    621
    I believe ColoradoBoo has a regular Prius, not Prime. My owner's manual says the spark plugs are to be changed at 12 years or 120K miles. We have no transmission, so no transmission oil to change. The manual says to replace the engine/inverter coolant at ten years or 100K miles. Not sure what "inverter coolant" is.
  8. bisco
    52,838
    cools the inverter and ecvt
  9. Washingtonian
    726
    621
    Is that the same coolant/radiator system that cools the engine? Or is it a separate system?
  10. FuelMiser
    1,349
    929
    Monument, CO
    separate system.
  11. FuelMiser
    1,349
    929
    Monument, CO
    I had wondered the same thing. 6,000 miles on a 2017 doesn’t seem right
  12. ColoradoBoo
    1,348
    972
    Changing your coolant in the radiator and transaxle in the Gen 4 (2017-2022) is SUPER easy:
    -Get 2 Gallons of Toyota Super Long Life coolant (You'll only need a gallon and a half)
    -Get the car up but level...remove the big plastic cover underneath.
    -Open up the radiator cap (if yours has one, some don't) and open the fill cap on the two coolant tanks
    -Put a large coolant drain pan on the left (drivers side) of the radiator and you'll see two drain cocks...mine are white and yellow...and open both up....it will take a long time to drain all the gallon and half so needs patience.
    -Then you just refills the two tanks and put into Maintenance Mode and top off as it gets sucked down. If memory serves me right, you need to wait for the radiator electric cooling fan to come on twice to ensure it's coolant is full...can take over 20 minutes.
    There's an excellent video on the Car Care Nuts' channel...some hybrids have drain plugs on the transaxle but our 2017 didn't have that...but the drain cock worked great, just takes a lot longer.
    If your Prius has the radiator cap, and you change out coolants in multiple vehicles, getting this thing from Amazon is great...has adaptors that fits numerous makes:
    Ultimate No Spill Coolant Funnel Kit - 19-Piece Spill-Free Radiator Funnel Set, Spill Proof Radiator Bleeder Kit, Coolant Filling, Radiator Filler, Extra Funnels and Adapters for Universal Vehicle
    Washingtonian likes this.
  13. bisco
    52,838
    there's a separate reservoir, coolant loop and pump to keep the electronics cool. same type of coolant though.
    you'll find the small reservoir in front of the bulkhead, driver side
    ColoradoBoo and Washingtonian like this.
  14. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    "put into Maintenance Mode"
    What is this?
  15. ColoradoBoo
    1,348
    972
    It's a way to make the ICE engine run without being turned off by the computer in order to do various maintenance things. (But we are cautioned from using it for long periods of time...not good for hybrids.)
    To turn on maintenance mode can be tricky....took me a while to get the hang of it:
    (Before starting, put emergency brake on)
    No foot on brake, push the start button.
    Push gas pedal to floorboard twice
    Push the start button
    Press brake and put car in neutral
    Push brake and push the start button...engine should start and display says something like "2WD Maintenance Mode" (My AWD says something else but I don't remember what it is.)
    The Car Care Nut has a video of him doing it for you....very useful when draining/filling coolants to get the ICE engine running normally.
