Buying a 2008 Toyota Prius. What should I check?
Discussion in 'Newbie Forum' started by BobWi, Feb 15, 2013.
  1. BobWi
    BobWi New Member
    I'm planning to buy a 2008 Prius with 100,000 miles from an owner, not a dealer.
    I never had a hybrid car before so I'd appreciate any tips. What should I check to make sure I'm buying a car in good condition?
    Thank you.
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    If no icons appear on the dash when running and it drives well, I'd get it to an OBD2 port reader to check for any codes, but what you see is what you get, great cars
  3. BobWi
    BobWi New Member
    Thank you, URSLE.
    Do you know how to check if the CVT transmission is ok? I've read that if there is something wrong with it, it should be a deal breaker.
  4. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Find a dealer with an 08 you can test drive so you can compare it to the one you're considering buying. That way you'll have a better idea if the private party is trying to sell you lemonade.
  5. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    Check his service records. Has it been serviced reasonably well? If he doesn't have the service records ask where it was serviced and call them. Ask where he bought it and call them. You need the VIN. Go to the Toyota owners website. Register there and plug in the VIN. It will provide the service info recorded in the system. Does the engine turn off at stop lights? Does the engine shut off going 40 with the cruise on and travel on electric for about a mile then the engine kick on again? It's about time for the 12V battery to get weak. Check the voltage. Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
    The 08 is not that old and 100,000 miles is not that much for this car. It would just be reassuring to know the owner took care of it. Why is he selling it? Was it garage kept? How are the ries? Are they LRR? How are the fluid levels? It is most likely a good car but the more information you have the better judgement you can make.
  6. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    If you get the vin and log into the Toyota web site you can pull the service record. Compare what he did to what is recommended. You can upload it here and we can look at it. The obvious is regular oil changes, a 100K tune up, did he replace the transaxle fluid, break fluid, radiator fluid, replace the 12V battery etc. If he is missing something ask to have that cost deducted from the price. If he did not replace the tyransaxle fluid that may be a show stopper since the failure can cost several thousand. The most important part of vehicle long life is constant fluid changes.
  7. bisco
    49,542
    reset the mpg meter and take it for a good long drive to make sure it's getting 50 mpg or so.
    JMD likes this.
