Buying a Gen 3 question/advice
Discussion in 'Gen 3 Prius Main Forum' started by Prius 49, Jan 12, 2020.
  1. Prius 49
    Prius 49 Junior Member
    Tucson, Az
    I am in the market for a used Prius in the Tucson area. I'm wanting to learn more about 'when' an auxiliary battery would need to be replaced? I would think mileage would be the biggest driver, but wanting clarification. For example, would a 2015 with 120k miles be better then a 2012 with 80k miles, or vice versa. Thanks!
    49,397
    do you mean the hybrid battery?
    the aux 12v battery is probably good for 4-5 years in the desert heat. 200 bucks for a new one.
    for the hybrid battery, the 2015 would be much better. but a 12 with 80k isn't bad at all. i'd be more concerned with the head gaskets.
    still, the hybrid battery won't last forever, so that should be in your budget
    #2 bisco, Jan 12, 2020
  3. Prius 49
    Tucson, Az
    yes hybrid battery. the expensive one.
    Thank you!
    #3 Prius 49, Jan 12, 2020
