Buying a Used Prius - Can avg mpg of 36 be right???
Discussion in 'Gen 2 Prius Fuel Economy' started by driving-mr-mel, Aug 21, 2010.
  1. driving-mr-mel
    driving-mr-mel Junior Member
    Dubin, PA
    Hi everyone. As a horse owner, trailer tower, long-time truck owner, I'm looking into trading in my 15mpg Ford truck for a Prius. I just can't afford the gas anymore or the expensive maintenence costs! I have a couple questions that I thought you could help me with. Honestly, especially in this economy, I don't trust the car salesmen or the dealers to tell me the truth!
    I drove a 2007 Prius with 46k miles today, and noticed that the average mpg display showed 36mpg over 242 miles. Is that possible? Are the displays accurate? If so, should this be a red flag? I don't want to spend the $$ or give up my truck for 36mpg. My mom does better than that in her cheap Corolla. This car also has 2 owners over only 46k miles, maybe thats why?
    Is there anything special I should be looking for that would be a red flag? I've found a loaded 2007 (Prius V) with under 50k miles, and they're only asking $12,000. Its at one of those tiny used car dealerships. Is that one of those, if it sounds to good... Thanks!
  2. john1701a
    john1701a Prius Guru
    12,747
    5,243
    57
    MPG as low as 36 is typically an indication of driving only extremely short trips (just a few miles). 2007 with 46k miles would tend to confirm that.
    Short trips are MPG killers. The reason is the emission's system must be hot to cleanse exhaust, so the engine runs generously at first to warm it up. That uses quite a bit of gas in comparison to the MPG that follows after it warmed.
    Resetting the display after warmup is complete would be one way to get a better idea what that Prius is actually capable of.
  3. jstraw20
    jstraw20 Member
    122
    Long Island NY
    If the car was at a dealership you were probably seeing the result of a lot of short test drives. The '07 I bought a couple of months ago was reading something around 36 mpg when I took it for a test drive, it's currently averaging around 53.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,122
    SF Bay Area, CA
    Totally concur with the others about the short drives. At minimum, run a Carfax check on it and if it's even been issued a salvage title or totaled, run away. Also, if you can get it checked out by a good mechanic, I would.
    Yep, 36 mpg is definitely possible with short drives, poor driving and a bunch of other factors (like wrong and/or underinflated tires and wrong or overfilled oil). See ConsumerReports.org - Most fuel-efficient cars for what the generation of Prius got in Consumer Reports' testing.
  5. ken1784
    ken1784 SuperMID designer
    2,940
    1,359
    67
    Yokohama, JAPAN
    Just a quick note, Prius has zero towing capability.
    Ken@Japan
  6. cwerdna
    12,544
    2,122
    SF Bay Area, CA
  7. driving-mr-mel
    Dubin, PA
    OP here. Yes, I know I can't tow with it! That's a funny image though.
    I have a 15 min commute to work every day. Is that too short for the Prius to get the 45ish mpg??
  8. richard schumacher
    7,663
    1,037
    United States
    15 minutes is long enough to warm up, so if there are not many stops on the way (no more than about five) then no; mine did that well.
    Do pay to have the car thoroughly checked out by a Prius technician (usually at a Toyota dealer) before you buy. That can prevent a lot of grief; you do not want to buy one that has been in a serious accident.
  9. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Even worse case if you drove 2miles a day, the Prius will give you the best milage out of anything else out there (as far as USDM cars go that is). Other cars have a warmup cycle too, and once it is over you are still in a less than great mpg area. At least with the prius, you have the opportunity to get great milage, even if you do not.
    With what you describe I would not be surprised if you get 45mpg with no effort or change to driving style.
  10. ken1784
    2,940
    1,359
    67
    Yokohama, JAPAN
    My wife used to drive 2 miles (10 minutes) a day.
    Our 2.2L Honda Accord recorded 6km/L (14mpg) on such short trips in winter, then Prius records 14km/L (33mpg) on the same situation.
    We are happy to see the Prius number.
    Ken@Japan
    2 people like this.
  11. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    509
    63
    For short trips it may worth investing in an engine block heater. Good luck! :)
  12. driving-mr-mel
    Dubin, PA
    Thanks everyone! I'm picking up my "new" Prius tonight. It's a 2008 with 28k miles. I've been looking through the posts, and am a little overwhelmed with all the prius tech talk, but hopefully I'll learn! For right now, anything better than the 15mpg I got with my truck will be wonderful.
  13. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    Congrats!
    Try the Prius II article by xcel over at cleanmpg.com
    Learn pulse & glide for speeds under 42 mph.
    Good lucK!
  14. driving-mr-mel
    Dubin, PA
    Thanks - I can't find that article?? I found one on Prius I, and Prius III, but not Prius II. I'm having difficulty having to scroll through forum after forum. Does anyone have a good link to a layman's FAQ on getting a new hybrid. Just figuring out what "pulse and glide" is will be a good start! Thanks!
  15. Codyroo
    Codyroo Senior Member
    1,826
    514
    Pleasanton, Ca
    Best advice I've seen on these forums.
    Take the car and just drive it for a couple of weeks. Get used to how the car "feels", accelerates, handles, brakes. It will be a subtle but noticeable difference.
    Fill it up when you are down to "two pips" on the gas (guess) gauge. There is a bladder in the gas tank that is there to prevent gas vapor from escaping. This helps the atmosphere, but since the bladder is flexible, it means you never TRULY know how much gasoline is in the tank. Fill up at two pips and it won't matter.
    Get out your tire pressure gauge, measure the tire pressure, and inflate the tires as needed. The closer you get to max recommended tire pressure, the more your fuel mileage will increase. You can back off if you think the ride is too harsh, but I'm guessing coming from a truck, it won't likely be an issue.
    During the next couple of weeks, get familiar with terms and information here. There is a wealth of information available.
    Pulse and Glide - Moderate to Brisk acceleration (not granny driving, not flooring it) to get up to speed and beyond. Let off the accelerator pedal fully and then lightly press on it (to remove any engine braking). It will be like coasting in neutral and you coast down below the speed you want. Accelerate above and repeat. Please do not do this in normal moving traffic. However, it is easily done in slow and go or even stop and go traffic (you just have to leave a bigger gap in front of you to pull it off). On a country road with light traffic, it can easily be done.
    Good luck and I hope the car works out well for you!
  16. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    Here you go:
    Pulse and Glide plus Warp Stealth in the Prius II for maximum FE … - CleanMPG Forums
    (There is a link to it on the home page.)
    Study that and related PriusChat threads and follow the 3 Ps: practice, persistence, and patience. I still occasionally fine-tune my technique after several years of optimizing fuel economy.
    I agree with the recommendation of an engine block heater. It can make a significant difference on short trips.
  17. just2plain2
    just2plain2 Junior Member
    danielsville georgia
    The 2008 I just purchased showed 36 on the lot. My wife questioned it and asked if we could take for a longer drive. We cleared display and came back @ 49 average. Great car
  18. driving-mr-mel
    Dubin, PA
    Thanks - I picked the car up last night. It's going to take some getting used to, but I love it already! How do I go about getting an engine block heater? Is it something I can have installed? I'm not exactly mechanically inclined! Are there good types, bad types, etc?
    Thanks again!
  19. 2009Prius
    2,705
    509
    63
    There are threads about engine block heater you may look up. It's made by Toyota Canada and sold by some US Toyota dealers. I bought mine from Toyota Scion Parts Accessories Discounted Prices - Metrotpn. Any competent mechanic or dealer would be able to put it in for you. Be careful not to flex the plug too much and secure it well when stored. The wiring tends to break near the plug. Good luck! :)
  20. Gutsy
    Gutsy Junior Member
    30
    Yardville, New Jersey
    I purchased a used 2008 Prius package 6 with 57,000 miles on it for $13,500 with a clean car fax about 2 months ago (I also own another 2008 Pkg 6 too). The display showed an average of 34 mpg when I first test drove it. Before purchasing it I had my local Toyota dealer do a complete diagnostic of the car for $69. The car passed their review. The only thing it needed was an engine air cleaner and cabin air cleaner.
    When I brought it home I reset the display, inflated the tires to 42 front and 40 rear (tires were in the mid 30's) then drove it for a 30 mile drive local and highway speeds and got an average of 57 mpg on my maiden voyage :) I'm currently getting an average of 54 mpg fr the past two months... which is what my wife is also getting on the white '08 Prius. I'm very pleased and I'm sure you will be too. Good luck with yours!
