Buying a Used Prius in 3 HRS! - What do I need to know?
Discussion in 'Gen 2 Prius Main Forum' started by macmaster05, Sep 28, 2009.
  1. macmaster05
    macmaster05 Senor Member
    4,050
    730
    In about 3 Hours (!!!) I will be buying going back to the Toyota Certified PreOwned Dealership to buy a Used 2009 Prius Touring. I've test driven it before and believe there is nothing wrong with it. It's prior owner was the dealership; it was used as a track car and has about 10,000 miles. However, before I go there, I want to know;
    1. What, specifically, should I check for on the car?
    2. Will someone at the dealership show me how to use all the features (NAV, Bluetooth, Garage Link)?
    3. What other things should I ask to see?
    Thank you! I'm so excited....
  2. Doc Willie
    1,717
    144
    Out there, somewhere
    1. If you can get a mechanic to check it out.
    Get a CarFax report.
    Look at the reflections on the doors and body panels. Ripples will tell you that they have been dented and repaired.
    2. They should. Dealers vary considerably on how much they know and how much they will tell you. Some will tell you wrong stuff. You can test him/or her by asking what "B" on the shifter means, and when to use it (Braking mode, to be used only onl lond downhills to avoid overcharging the traction battery).
    Make sure they have the owner's manual. Plan to read it twice. It is long.
    3. Look in the storage areas under the hatch to see if the tire changing tools are there.
  3. a_gray_prius
    2,927
    783
    IL
    1. Don't be excited. A calm car purchase is a smooth car purchase. Being excited often leads to overlooking important details.
  4. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    2017 Prius Alpha
    Make sure its really a touring model... Another PC member recently said he was deceived about that...
  5. macmaster05
    4,050
    730
    How do I make sure it is a touring for sure. It has the bigger looking wheels (7 spoke) and the bigger spoiler. I can't tell the suspension though, or can I?
  6. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Make sure you get 2 sets of Keys. See if the original window sticker is in the glove compartment and make sure you get all the options listed, ie. floor mats ect.
  7. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    Don't get too excited. If anything looks fishy, put on the brakes and sort it out. If you can't sort it out, walk away. You can find another one.
  8. jpadc
    343
    34
    2017 Prius Alpha
  9. macmaster05
    4,050
    730
    Thanks everyone! I DO have the car and have only driven it home. But I love it. I programmed my HomeLink, radio stations, and bluetooth phone, so far. Still have to learn the navigation system.
  10. tredstone
    tredstone New Member
    116
    Queens, NY
    Awesome! What mods do you have planned?
  11. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    Geeez... let him drive it for a few days....
  12. macmaster05
    4,050
    730
    Oh did I.
  13. bisco
    51,155
    what are you doing?
  14. macmaster05
    4,050
    730
    Nothing anymore. I'm retired. I've completed every mod I ever wanted to do...except rims. Rims are dependent on tires, and I don't need new tires yet.
