Buying a used Prius, what should I look for?
Discussion in 'Gen 2 Prius Main Forum' started by xzzz, Jan 26, 2013.
  1. xzzz
    xzzz Junior Member
    Phoenix, Arizona
    There are four Prii I'm eyeing currently, all in the same ballpark price range. They are:
    2006 Base 80k miles ($10k)
    2008 Base 70k miles with package #5 ($13k)
    2008 "Touring" 80k miles ($13k)
    2008 Base 30k miles Certified Used ($15k)
    How important is mileage on a Prius? The 30k miles one is a two-owner car, and the second owner (who had it for ~4 years) had a suspiciously low miles/year rate of under 3000 miles per year.
    Is there anything I should look for when I go onto the lot and inspect the cars themselves, or anything to look out for in the service history? I've already seen the first Prius in person (2006 Base with 80k miles) and one thing that concerns me is that there's significant rust on the driver's seat track. Is this expected for a Prius that's been driven in an area with a lot of snow and salt? (Buffalo, NY) How susceptible is the Prius to rust in general? The third Prius (2008 "Touring") was bought and driven in Florida for 95% of its life, is that something to take into consideration? I live in Buffalo, NY.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Buy a Florida car. Mine looks brand new underneath. Reports of bad rust on up north cars.
    I don't like the car with the rusted seat track. That may mean the interior got flooded. At the least that area saw alot of moisture. Not good.
    Millions of salvaged wet cars out there post Irene and now Sandy. And just because there's no salvage title does not necessarily mean the car did not get wet in the cabin. If your serious about a car pull the spare tire out of the back. If the car got any water in it there will be rust in that bottom storage area there especially under the tire. My tire well by comparison looks brand new.
    Should have no corrosion under that tire. If any corrosion pass.....because that means somewhere somehow the cabin saw significant moisture which for a Prius is very bad. So many ecu's and wire harness's in the cabin that could corrode. You'll end up with an intermittent electrical system that will drive you & the dealer & your wallet nuts.
    Good luck.
    JMD likes this.
  3. xzzz
    xzzz Junior Member
    Phoenix, Arizona
    Thanks for responding. Are there any other good places to look for rust? Or any other signs that the car may be a potential lemon?
    Also, I received an Autocheck from the dealer (independent dealer, not affiliated with Toyota) for the Florida car, and the last entry is "REPORTED AT AUTO AUCTION" from just last month on December 17. I figured that's how it found its way up here in NY from Florida. How concerned should I be about this?
    I'm also going to take the car to get it inspected, would it be a good idea to take it to the local Toyota dealer's service department? I figure they'll have more experience working with hybrids than the average auto shop.
    49,618
    i like the 08 with 30k. how long do you expect to keep it and how many miles per year? i had an 08 and it was a great year. no issues whatsoever. whatever you do, make sure you take it for a good long drive in varying conditions. don't let the salesman come with you and try to distract you from concentrating. check all the the buttons and switches to make sure everything works. the battery indicator should stay near the middle except occasionally when it may go very high or low based on driving conditions. all the best!
  5. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Have the dealer do the inspection.
