Buying Advice needed-2008 w/81k miles
Discussion in 'Gen 2 Prius Technical Discussion' started by danneskjold, Dec 21, 2018.
  1. danneskjold
    danneskjold Junior Member
    Hi All,
    I'm looking at buying a 2008 prius with 81k miles. It has a good service history-oil changed at the dealer every 5k miles since new, only one owner.
    On a 9 mile test drive it started with the battery one bar below full, discharged to two bars, and recharged to 4 bars by the end of the drive.
    We only averaged 31 MPG on city roads-45 MPH speed limit, some stoplights mixed in.
    Is this considered normal mileage for this situation, or does it indicate something wrong with the Traction battery?
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Hi-
    Problem is your probably not a Prius hybrid battery expert so your at the mercy at whatever the salesman or the owner tells you.
    I can tell you its the main reason I think most people sell there Prius the battery is showing diminished power. Bottom line is it may fail real soon after you buy it. Whats your expectations and finances to fix it? Its expensive and time consuming and possible tow's if you don't have any technical skills and a place to rebuild the battery.
    Try this go to toyota.com/owners and join the forum. Your going to need the VIN on the car to check it. Using that vin join the forum and it will tell you the records of every time its seen a authorized toyota dealer and what was reported.
    Don't be surprised to find the dealer has condemned the battery. Seen many posts here of just failed hybrid battery's on bought recently used Prius. Everyone is highly attracted to the mileage savings but one good repair will blow those savings out the window.
    There's a good prius reseller in Lutz Florida how far away are you from Tampa? He sells alot of Prius with new battery's or professionally rebuilt battery's.
    This guy:
    Home - Tampa Hybrids Inc.
    Todd is a good guy alot of us on this forum have bought cars or parts from him.
    Good Luck!
    strawbrad, Skibob and bisco like this.
    52,354
    welcome!
    did you reset the trip meter and start with a warmed up engine?
  4. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    I will add that low mileage 2nd gens are often not a good buy. The hybrid battery in these likes to be driven every day and will reduce capacity more quickly if it's not. Often lower mileage examples sat in someone's driveway without getting driven for a lot of their life. However if there's good evidence the previous owners drove the car short distances every day, it may be worth the risk. For 2nd gens, I think between 125k to 175k are generally better values for the money.
    edthefox5 likes this.
  5. jbusta
    jbusta Junior Member
    33
    So I'll tell you my n=1.
    I bought my prius from my mother-in-law
    2008 Prius with around 85000mi last year. She was the only owner, serviced it timely with Toyota Dealership like clockwork
    Everything was working well until about 14 months later when my battery failed and I got the red triangle of death. I ended up needing a new HV battery (got a refurbished one for $1550) and the car is back to smooth sailing
    I had the same concerns as you initially, but everyone says these HV batteries last up to at least 150K mi. I guess I'm just one of the unlucky ones
    And this was a car from my mother-in-law who I know and love. If it can happen to me, it can happen to anyone
    I knew the risks of buying an older car with the original HV battery and was ready for the consequences (don't think my wallet was)
    Good luck
    (edit: I just re-read your post and 31mpg sounds terrible. In retrospect my MPG went from 43 to 35 after a little over a year before the battery failed)
  6. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    This is a really good post. When people buy a Prius the concern about the battery is justified, it’s a major cost. I feel if you factor in the cost of a $2500 battery to the cost that you’re paying for the car then you can understand whatever value you can get out of buying a used Prius. I’ve driven my 2005 PRIUS 537,000 miles I repaired everything from the trans axle and the engine to the taillights. The battery has become my best friend. I think of it as a flashlight, rather, a rechargeable flashlight with 26 batteries and if any one of those batteries go bad the entire system goes down. Initially, I was intimidated by this flashlight that had 26 batteries in it, then, when I took it apart, it became my friend. So don’t be afraid to buy the Prius, savings in gas will be about half what you would have spent on any other car. Enjoy those benefits until your first battery goes out and then invest in replacing the cells of the battery that have gone bad. I can tell you driving a 2005 Prius with over 500,000 miles on it, it’s a great ride.
    iPhone ?
  7. golfmk681
    golfmk681 Active Member
    264
    105
    los angeles, ca
    Wow that’s amazing. How long have you had the Prius? What is the type of oil brand (synthetic or conventional), and how often do you change the oil. I’m hoping to hit 500k on my car. It’s kind of a badge of honor I think to have a extremely high mileage car.
  8. Paul Schenck
    524
    307
    Fresno, California
    Castrol Edge synthetic change it every 10,000miles I’ve had it since Father’s Day 2005
    iPhone ?
  9. golfmk681
    264
    105
    los angeles, ca
    That’s great man! Amazing.
