Buying advice?
Discussion in 'Prius v Main Forum' started by BioArch1491, Dec 11, 2023.
  1. BioArch1491
    BioArch1491 New Member
    Arizona
    Hey all! So, I've been looking at getting a Prius V for quite some time, and am not only now in a position to do so, but I've found a few that look good. Its hard to find ones that have few miles and no accidents, but I found some that fit. So what I'm wondering is:
    I've found 2 in particular that I'm looking at - a 2014 V Five with about 80,000 miles, and a 2012 V Five with about 65,000 miles. I know that the V's are prone to head gasket failure when they get to somewhere around 100k to 150k miles, but I also know that the hybrid batteries start to show their age once they exceed about 10 years old.
    With all that, do y'all think one is a better choice than the other? A 10 year old one with 80k miles, or a 12 year old one with only 65k miles? [Edit: the 2012 is *slightly* cheaper, for added context] Any thoughts are appreciated. Thanks!
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,314
    6,454
    Texas Hill Country
    A 2015-17 v would be the only one I would consider due to the bad ring and piston design of the 2012-14 models.
    2012–4 v’s have poor crash ratings as well which was reengineered for the 2015 models.
    More of the later models have advanced safety systems and are less likely to have inverter and brake by wire “brake booster” problems. Obviously the newer cars will have better hybrid batteries, some still in warranty (in carb states) with 10 year 150k hv battery coverage.
    Clearly a downside of a 2015-17 v is they still have gen3 engines while the newer 2016 hatchbacks came with much improved gen4 engines. These were used until the 2023 gen5 Prius came out. Derivatives of gen4 engines are commonplace in RAV4 and Camry hybrids even today.
    If I were forced to buy one of your choices, it would be the 2014 as it has two less years on the systems and it would take a bit longer before the $5k-$10k worth of repairs started accumulating in my ownership. But you are gambling with a 2012-14 v; many owners have to replace the engines. Some buyers are scammed with temporary sealers to mask head gasket fails.
    Because people fall in love with a Prius anyway, I would certainly find a highly qualified independent hybrid shop for pre-purchase inspection (difficult to do on the expensive hybrid parts). I would have them ready for the engine oil burning, brake booster, hybrid battery, head gasket and other smaller maintenance expenses like the water pumps and coolant systems.
    In reality the best value in today’s upside down car market are new cars. Perhaps a Corolla Cross hybrid with the new Prius engine and hybrid system.
    For the first time, power and mpg in a value priced hybrid. Lower interest rates on a new car can often provide competitive monthly payments. I would never finance a 2014 v for more than 18-24 months especially at today’s 8-10% used car rates.
    #2 rjparker, Dec 12, 2023
    JohnPrius3005 likes this.
  3. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    12-14' all junk with stock engines with who knows what kind of maintenance...save and find a 15-17' and get the revised pistons and face lift..
    Tim Jones likes this.
    52,165
    i'd go for the 14, hope it got the revised pistons and rings, and jump on the egr
  5. Mendel Leisk
    41,730
    Piston ring update on the Prius v "might" be a little later, not sure. See linked for VIN number when the change occured:
  6. rjparker
    10,314
    6,454
    Texas Hill Country
    Prius v pistons and rings 5 yr 60k
    #6 rjparker, Dec 12, 2023
  7. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    NO..................! You have already found out several of bad things that happen and cost thousands....and there are more..... I would not pursue it... do yourself a favor and get a Non Hybrid........... or go a head and do it and rember my post as you watch it being towed away with thousands in repar bills.
    #7 Tim Jones, Dec 13, 2023
  8. MattFL
    MattFL Member
    187
    55
    Wow all the FUD around here. Maybe I'm just lucky so far, but our 2012 Prius just crossed 100k miles and is so far doing great. Uses zero oil as of yet. The brake booster was replaced under recall and the A/C needed a repair, but otherwise so far so good. I did notice it doesn't use the traction battery much if it's very hot outside and the car has been sitting in the sun (I'm in S. Florida), but it's back to normal as soon as things cool off.
  9. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    Your not at 150,000... but you already had the brake problem and AC... but traction battery getting pretty old. Have you changed the trani fluid and cleaned the entire EGR system and intake manifold?
  10. MattFL
    MattFL Member
    187
    55
    I did change the transmission fluid some time ago, have not touched the EGR system. Have spark plugs on my ToDo list. What is the symptom for the EGR needing to be cleaned?
  11. Mendel Leisk
    41,730
    Anything over 100k miles on the odo. Head gaskets start blowing around 150k.
    see top 2 links in my signature; on a phone turn it landscape to see signature
  12. rjparker
    10,314
    6,454
    Texas Hill Country
    It gets more irritating when you are stranded 100 miles from home with a sudden inverter failure, hv battery around 150k, oil burning starts around 125k with major engine work by 175k and maybe a cat by 250k.
  13. MattFL
    MattFL Member
    187
    55
    What is the cause of head gasket failures?
  14. rjparker
    10,314
    6,454
    Texas Hill Country
    Leaking seal material on the metal gasket between a coolant passage and one or more cylinders. Traditionally caused by overheating and warped surfaces. Toyota revised the sealing material in replacement gaskets. They also revised gen4 cylinder cooling strategies specifically for hybrid engines with wide thermal swings due to frequent engine off periods. Gen4 also reduced carbon introduced by the egr system (not used in gen2) by taking exhaust after the cat. Overall a flawed design highlighted by low tension rings, revised under warranty for 60k in gen3 and all gen3s mid 2014.
  15. Mendel Leisk
    41,730
    I think the primary cause is clogged EGR.
  16. V Sport Wagon
    375
    131
    Southern California
    You sure seem to like posting this all the time even though there's evidence on the contrary that says it's a small factor, not the primary cause. Primary cause is old coolant, old waterpump, driving style...then on down the line.
    Mendel Leisk and Brian1954 like this.
  17. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    Let's see THE (your) evidence....... links...technical toyota papers...others?
  18. V Sport Wagon
    375
    131
    Southern California
    Toyota doesn't talk about EGR cleanings, which would assert I am right. But they do mention coolant change intervals..which you can read about anywhere and in your owner's manual.
  19. MattFL
    MattFL Member
    187
    55
    If corrosion caused by old coolant is a potential cause of the head gasket issues, then that's an easy preventative, time to change the coolant!
    V Sport Wagon likes this.
  20. Brian1954
    Brian1954 Senior Member
    2,323
    925
    South Central PA, USA
    V Sport Wagon and MattFL like this.
