Buzzing noise when turning off car?
Discussion in 'Gen 2 Prius Technical Discussion' started by Paul Perry, May 6, 2014.
  1. Paul Perry
    Paul Perry New Member
    Hello all!
    Just purchased my first prius, a used 2008 w/ 73k on the dial.
    I noticed a weird noise when I turn the car off, I hear a buzzing noise coming from the engine compartment when I turn the car off, and it lasts for maybe 30 seconds.
    Is that normal? Any opinions?
    Thanks,
    Paul
    49,443
    welcome to priuschat! normal, all systems go.:) did you get a manual? it describes all the weird noises.;) all the best!(y)
  3. Paul Perry
    Cool, thanks! No, didn't come with the manual. Also, only came with one key fob. Looking forward to the 'chicken dance' with a ebay fob....
    Much appreciated!!!
    49,443
    i think you can get a manual at toyota owners website. good luck at the prom!:p
    dorunron likes this.
  5. JPTuck
    JPTuck Member
    110
    29
    South Deerfield, Mass
    Mine often buzzes like that - I believe it might have to do with the hybrid cooling system from what I could tell from my manual.
  6. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    From what I was told by the dealer, there is a pump under there that moves hot coolant to a "thermos" insulated container. It's saved there and pumped back in to make future engine starts more efficient. Not sure if that's correct, but sounds good to me. ;)
  7. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    WNY, what you said is basically what needs to be said...
    Ron (dorunron)
    WNY-HYBRID likes this.
