Buzzing/Rattling sounds at low speeds
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ou_chot, Jul 19, 2011.
  1. ou_chot
    ou_chot New Member
    plano, tx
    Just purchased 2007 Prius Touring model w/ Package 6. Wonderful car.
    Quick question: Is it normal to hear a buzzing/rattling noise when stopping at low speeds or starting at low speeds?
    It seems to be coming from the drivers side. Doesn't happen every stop/start.
    Thanks for your help.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    That is the accumulator pump in the brake actuator. Perfectly normal.
  3. ou_chot
    ou_chot New Member
    plano, tx
    Is it normal for the buzzing to happen several times during a given ride?
  4. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Yes, it is normal. The pump maintains pressure in the hydraulic brake system. An electric pump is necessary because a vacuum booster pump would not work, since the engine is not always running.
