Buzzing sound upon opening driver door
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by PanthersFan, Mar 29, 2016.
  1. PanthersFan
    PanthersFan Junior Member
    55
    17
    South Florida
    2013 Prius v wagon
    Each time I open the driver door, when the car is off, I hear a buzzing coming from the front (left?) of the car. It sounds like something electrical. What is it and is it normal? Assuming it's normal, I like it because it's kind of like the Prius saying hi and it reminds me I now have a unique (and fun) car. But what is it? Am I wasting battery with something I've left configured?
  2. Colin
    Colin Junior Member
    33
    That's the vacuum pump for the brakes. The car needs to have an electric pump so that the brake assist works when the engine is off.
    PanthersFan likes this.
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    I don't think it's a vacuum pump, but it is a pump. ;) It's pressurizing the brake system.
    Stacey2015 and PanthersFan like this.
  4. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    ABS pressurization pump.
  5. Stacey2015
    Stacey2015 New Member
    San Francisco, CA
    The same noise occurs when I open my 2015 Prius car door. Is there any action I should take to fix this, or is it something I can leave be without worrying about?
  6. mikefocke
    3,701
    1,649
    Sanford, NC
    Ignore. Normal. Sometimes you hear it as you walk up to the car without even touching it. Sometimes several seconds after exiting the car.
    darylofearth likes this.
  7. ChapmanF
    15,652
    The only time to worry would be if you don't hear it.
    That's your brake accumulator pump, building up the brake fluid pressure for you so that you will be able to slow and stop the car at times of your choosing. They think of everything, these guys.
    -Chap
  8. Stacey2015
    San Francisco, CA
    Woohoo, thank you!
    Glad to hear it, thanks!
    #8 Stacey2015, Sep 6, 2018
  9. KngkCrls
    KngkCrls New Member
    2013 Prius v wagon
    I also noticed that the buzzing sounds repeats itself every 30 sec or so while driving. Is it normal? Same pump?
  10. bisco
    49,501
    yes and no
    it has to keep repressuizing, but increased frequency means the system is slowly failing
  11. Air_Boss
    3,952
    1,083
    New Yawk
    Or you have an ABS system leak-down, whether in the pump or elsewhere.
  12. KngkCrls
    KngkCrls New Member
    2013 Prius v wagon
    Would I get a warning light because of that?
  13. KngkCrls
    KngkCrls New Member
    2013 Prius v wagon
    If there is a leak, I should see a spot where I park, no? That is not the case though. Would I get a warning light it that is the case?
  14. bisco
    49,501
    it doesn't leak out. sometimes there is a warning, sometimes the brakes operate more like manual than power.
  15. Air_Boss
    3,952
    1,083
    New Yawk
    This would not be an external leak, it would be an internal leak past seals, a loss of pressurization that requires frequent re-pumping up to operating pressure parameters.
