  1. risinglava
    risinglava New Member
    California, USA
    Hi All,
    Anyone owning a Prius hear that weird buzzing noise when driving it? It sounds pretty high pitched. Does this annoy anyone? Forgot the mention, my Prius is a Gen3 2015 model 2.
    The Prius Gen2 does not have this because my friend owns one and it does not have that noise.
  2. JC91006
    16,482
    8,399
    I actually hear more noises in my Gen 2 than my 2015 Gen 3. The only buzzing sound you should be able to hear is possibly the brake accumulator pump, will activate every couple times you press the brake. Any other buzzing sound probably wouldn't be normal.
  3. risinglava
    California, USA
    It makes the noise when you drive the car. It sounds like the electricity dissipating from the battery or something like that.
    49,469
    could be inverter whine, maybe drive another to listen.
    The Electric Me likes this.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    My guess IS also that you are hearing the inverter whine.
    I believe from Gen 2-Gen 3 Toyota shrank some components, and the inverter in Gen 3 is different.
    I never owned a Gen 2. I don't really hear or I am able to ignore the whine with the my Gen 3 Prius. If yours is consistently noticeable, you might want to bring it up with your service department.
  6. JC91006
    16,482
    8,399
    you should have your dealer check it, it's under warranty. They'll tell you if it's normalactually the AC on the gen3 is quite loud, especially noticeable when you are outside the car with the AC on
    #6 JC91006, Jun 29, 2015
    matt b. likes this.
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Listen to loud music for awhile, or leave the window open on the highway for a while, or fail to use required hearing protection at work. It will damage your hearing enough you will be like most of us, unable to hear above about 8 kHz. ;)
    fuzzy1 likes this.
  8. fuzzy1
    10,167
    Or just wait a few years, until your high frequency hearing thresholds drops below the frequency of the whine :)
    At one time, the horizontal rescan of some traditional TVs, at 15.75 kHz, really annoyed me. By age 40-ish, that problem was completely gone. The TVs didn't get quieter, my ears stiffened with age and shut out that buzz. (In that era, I could confirm specific frequencies with lab equipment at work.)
    Recently, 50-something and playing a swept tone generator found on YouTube (lacking access to the previous lab equipment), I could hear up to only 13 kHz. So could my brother.
    But dad could hear only to about 1.5 kHz, with his hearing aids in place. No wonder he couldn't hear the shrill feedback oscillation of those devices when he took them out in the evening. I had to retrain him to turn them off, not only to quit annoying us, but also to improve battery life. This may also explain why he has more trouble understanding some females with higher pitched voices.
  9. bisco
    49,469
    what?
  10. risinglava
    California, USA
    You guys are totally funny. Yes I would have to re-train my ears to ignore the whine.
    Or I could bring it up with the service department and see what they can do about it. Hopefully fix it else if all Prius Gen3 owners complain hard enough they would do a recall and fix the inverters(thats saying that the inverters are the cause).
  11. fuzzy1
    10,167
    A whine alone is not a safety issue, so there will not be a recall.
    But if some units are significantly worse than normal, and enough owners complain, there might be a TSB (technical service bulletin).
    If the middle-age service writers and technicians can't hear it (aged related hearing loss seems to be inevitable), seek out the youngest staff available. You might need to try several of them, as loud music has caused a lot of premature hearing loss in young folks too.
    #11 fuzzy1, Jun 29, 2015
  12. bisco
    49,469
    it's buzzing, not fuzzing.;)
  13. David Beale
    5,963
    1,981
    Edmonton Alberta
    Inverter whine is "normal" in a Prius. I hear mine most of the time, and I'm 67. It's a good sound. Tells you you're saving money.
    I suspect it would be hard to eliminate as it's a 5-10 kW device. Lots of energy there.
    Perhaps some might complain about the exhaust note of, say, a Mustang? Or maybe not? It's easy to fix though. I'm told bananas up the tailpipe do it. ;)
  14. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Yes, it's probably inverter whine. I can always tell when a Prius or other hybrid is driving by me. It's a distinct sound.
    No one has mentioned it yet in this thread, but there is also the VPNS speaker that also emits a sound that some describe as a spaceship or flying saucer sound. I've never heard a real live flying saucer before, so I'm not sure. :confused:
  15. bisco
    49,469
    good point about the vpns, but only up to 15 mph. perhaps o/p hears it while traveling slowly with windows down.
  16. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Most of the time, huh? If it continues when you're far from your car, that good sound might be tinnitus.
    Seriously, at first I thought that whine was gear noise.
  17. risinglava
    California, USA
    This is with the windows up.
    The whine comes when the battery is being charged. It lessens when the battery is putting power back to the motor.
  18. Mendel Leisk
    38,718
    You'll hear the generator whine any time you're slowing. Our previous Civic Hybrid made a similar sound.
  19. bisco
    49,469
    any speed?
