By What Shall We Judge, Outcome or Intent?
Discussion in 'Fred's House of Pancakes' started by airportkid, Sep 15, 2011.
  1. airportkid
    airportkid Will Fly For Food
    2,191
    538
    San Francisco Bay Area CA
    It's the old ethical quandary: punish the deed or punish the intent. Likewise by what scale shall we reward: the magnitude of the deed or the magnitude of intent.
    Here's a soldier today being highly honored for the deed, which succeeded despite horrific odds of failure:
    Marine receives Medal of Honor at White House - CNN.com
    This will draw intense withering fire against me for saying so, but I believe the point worth voicing: I think giving this soldier an award is a mistake.
    Now, there's no question whatsoever that he acted selflessly, bravely, and successfully. All three of those, singly or together, are worthy of award.
    So why not in this case?
    Because in this case his first act was to disobey military orders. It isn't so much that he disobeyed orders, per se, but that he refused to act in accordance with superior judgement of the situation.
    The military succeeds in great part because it brooks no disobedience, that is to say, it demands action as determined by superior judgement; it does not permit the exercise of inferior judgement, nor the exercise of chaotic, disorganized individual judgement. Expedience and practicality require that this be determined by the simple element of rank, the assumption being that superior rank = superior judgement, augmented by superior knowledge. Obviously, this is not always so, but in the rapid confusion of battle one can't take the luxury of analyzing every case, so you go with what superior rank says and in the main it carries the day.
    The minute you condone exception to this rule, you open the door its complete breakdown.
    Giving this soldier an award provides an incentive for other soldiers to do the same thing he did, exercise indvidual judgement against the superior judgement of their commanding officers. The odds of success, over the long run, are LESS by doing that than by obeying orders. For every outstanding outcome like this there are a hundred that fail.
    Keep in kind that his orders to stand down were not corrupt, were not orders intended to personally enrich the officers, they were orders that IN THE BEST JUDGEMENT of his commanding officers would incur the LEAST DAMAGE. Such orders are aren't just good orders, they are the RIGHT orders.
    Disobeying them exposed the group to greater damage, that such damage did not occur does not exonerate the deed.
    To my mind, the way to handle a case like this would be to:
    A. PUBLICLY declare that the soldier is being sanctioned for the deed, with an explanation that permitting breakdown of military discipline unmoors the anchor of military efficacy. PUBLICLY declare than in light of the deed's success, the sanctions will be less severe than normal, but nonetheless imposed, to make clear to all concerned that all this was was a lucky break.
    B. PRIVATELY, to the soldier only, give some non-public reward (a year's salary perhaps) to both blunt the effect of the sanction and acknowledge the magnitude of the selflessness of the act. It's a mixed messgae, to be sure, but to only one person - and to that person it can be fully explained.​
    Several years ago a jet fighter engaged in mock combat collided with another fighter, completely severing the entire starboard wing (the other fighter was less damaged and landed safely). For aerodynamic reasons not fully understood, the unwinged jet did not instantly fall into a spin but remained upright, stable, and controllable. It was also spewing fuel. Its pilot, recognizing the aircraft was controllable, elected to not punch out. He stayed with it, as did his instructor in the back seat, and they landed the wreck safely with no further damage. For this act he was rewarded with a commendation.
    He should have been reprimanded severely.
    It was spewing fuel, and its controls were electrical. There was no way to know whether a control input would arc across a torn wire and blow the whole thing up in a split second, killing them both. It was a case of "bravado" judgement overruling good sense. They should have both punched out immediately.
    But, like our soldier in Afghanistan, the outcome came out OK - and the outcome was what got all the attention.
    So - what SHOULD get attention: outcome, or intent?
    It's a tough one, that one.
  2. amm0bob
    amm0bob Permanently Junior...
    7,730
    2,547
    Did you serve.
    2 people like this.
  3. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Deleted.
  4. ETC(SS)
    6,553
    It's a CONGRESSIONAL Medal of Honor...
    It's their call to make
  5. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    You are way over-analyzing this from the armchair. What you described certainly never matched what operations were like in my years of military service. "Orders" range from brilliant to destructive. They also range from "loose guidance" to "life or death" directives. Only on TV and Movies do they get all wrapped up about the "blind obedience" concerns. At the end of the day, you are responsible for your actions. That's the basic view of the vast majority of situations I was in both up and down the Chain of Command.
    You can also view this situation as the "orders" he received could be interpreted as he had no requirement to risk himself, not that he must blindly stay put. There are so many unspoken factors in what is stated and what is communicated. Often the two are very different.
  6. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Two of his superior officers were severely reprimanded. He did the RIGHT thing.
    Even the military sometimes gets things right.
  7. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Intent is a very difficult thing to judge.
  8. amm0bob
    7,730
    2,547
    Not for me... on the battlefield, we do not leave our comrades out there to die. And if we know they are wounded, we run to help bring them to cover... while I don't know if you have been under fire... I do know about it myself. And of men that never had another day...
    This Marine did what a Marine should do after they have been properly trained and believe they can make their adapted mission successful. He is exactly the kind of man to get such recognition.
    4 people like this.
  9. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    I am also curious AirportKid, did you serve? The awardee of the CMoH you are referring to is a Marine not a Soldier big difference.
  10. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I too feel that the OP's analysis is simplistic.
    "No battle plan survives first contact with the enemy"
    (Attributed to many)
    Intent/plan --> (real-world changing conditions) --> Outcome/Unintended Results
    What is prized most in troops and officers alike is the intelligence and flexibility to
    evaluate and quickly react to changes in a situation both good and bad.
    Rarely if ever can what happened in a skirmish be determined after the fact.
    The larger the action the less the liklyhood.
    Murphy's Law of Combat
  11. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    Has to be both.
  12. Trollbait
    11,541
    Did their actions put others at risk? Would bailing out have done so? They both elected to stay.
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The OP is also missing another point: An award like this is about more than just the recipient. This is a Congressional award, and sometimes (often) Congress does something to make a statement. Issuing this award is a statement from Congress that they support the bravery and sacrifices made by members of our armed forces and their families. Not many of these are given to living persons, but the value of the statement is amplified if the public gets to see a flesh and blood person standing there being honored.
    We can sit here on the sidelines and debate the merits of the recipient, but the fact is that this young man was nominated by his superiors and selected by Congress. To be considered, you have to do something remarkable. To actually win, the stars have to align: action, witnesses, nomination, and politics.
    Tom
  14. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    This article gives a bit more perspective on what really happened:
    Medal of Honor recipient saved 36 lives during battle
    His decision to defy orders and go in was, IMO, the correct decision. It's a situation where, as he said "I don't think there was ever a question in my mind if I was going to die, it was just when", there really is no order to go in - it's a volunteer assignment. In this case, he put himself at risk in order to provide support and save the lives of his fellow Americans (and Afghan allies). he didn't put anyone else at risk. He didn't risk anything other than himself.
    When we ask our military to put themselves in harm's way, they have to do so knowing full well that there is backup and support should they end up in a situation beyond their control. We can't just abandon them. Especially when 6 hours after the conflict started there were still men pinned down. That's more than enough time to send in all the help we can muster for them to get them out of there. The fact that their superiors said no to the simple request of risking their own lives to save their teammates is, in my mind, almost criminal.
  15. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
  16. ETC(SS)
    6,553
    One of the many things that (still) separate the United States from a lot of countries that end in "-stan" is the fact that we have a professional, voluntary, civilian controlled armed service.
    We in the military swear an oath before GOD (or make like affirmation, for the non-theists) to support and defend the Constitution, and to obey the lawful orders of the POTUS, and those appointed by him (or her.)
    LAWFUL orders.
    OK...so the sniveling, bed wetting attorneys are always reminding us that the law is like a piece of string. Fixed at both ends, and kind of loose in the middle so that which side of the string you're standing on can (and does) often change WRT YOUR situation, THE situation, or many other variables. Fine.
    So...
    Which side of the string was our Marine standing on when he and SSGT Rodriguez-Chavez (who drove the HMMWV, and was in charge of the evolution by rank and title) rescued their embattled comrades?
    I'm sure that some sea-lawyers out there have their opinions, but for me the answer is pretty clear. Rodriguez-Chavez was awarded the Navy Cross. Meyer was awarded "The Medal."
    Both of these awards followed a nomination and investigatory process, which means that a number of military professionals and civilian functionaries picked over such verifiable information as is available following a combat action, and reached a consensus.
    They seem to be satisfied that both of these Marines did the right thing.
    I'm satisfied that both of these Marines did the right thing.
    I'm pretty sure that the 36 people that were rescued and the family members of those that were recovered by this action would concur both with the empaneled experts and with my very unworthy assessment.
    Still.....
    We are a civilian controlled military.
    All volunteer.
    One of the things that we agree to when we swear or affirm is that there is a vetting process for after-action procedures, whether they be awards or disciplinary action, and that we're judged by those we serve---whether or not those persons have themselves served.
    That system is working....rather well, if you ask me.
    If APK wants to opine that SGT Meyer did the wrong thing, he is very well within his right to do so....whether or not he wears a CAR (Combat Action Ribbon) or has even served.
    People in the US (still) have a GOD given, Constitutionally protected right to be wrong.
    My opinion? (FWIW)
    I'll be honored to render my best very sharpest salute to SGT Meyer if I ever see him and I happen to be in uniform. Contrary to popular belief, there is no written law or regulation that requires hand salutes for CMoH holders. In fact...by the letter of the law, such honors may be "illegal" by the strictest interpretation of the uniform regulations.
    It's done by tradition, and more importantly because it's the right thing to do, and it upholds the highest traditions of the military service.
    Just like never, EVER abandoning your comrades when you have the means to render assistance---especially if they're nice person-deep in trouble!!
    JMHO....
    3 people like this.
  17. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I happen to think that this young Marine is well deserving of the honor - his actions were the embodiment of what the award is for.
    As to whether we should judge outcome or intent, you do have to weigh both but you have to realize that it is straightforward enough to quantify the outcome, but getting a handle on the intent is a whole different story. You can infer what the intent of an action was, but in many cases that is as far as you can get.
