C shows 2 bars after sitting
Discussion in 'Prius c Main Forum' started by Beel haze, Jul 12, 2021.
  1. Beel haze
    Beel haze New Member
    Alberta
    2019 Prius c
    My 2019 c often only shows 2 of 7 bars at start up, after sitting a day or 2. This is not weather dependent and I live downhill so I figure getting home would give it regen and put it higher. What is normal startup charge level....dealer answer added little insite
  2. Tideland Prius
    16,445
    The normal should be whatever you left it at when you shut off the car, especially after 1-2 days.
    Beel haze likes this.
    51,143
    unusual, how many miles/km on her?
  4. Beel haze
    Alberta
    2019 Prius c
    i think the answer from Tideland "should be where you left it" is the correct answer. It is not a plug in, so battery assists ICE..... we drive differently everytime, and the system reacts, to keep battery in a range. if stop and go, then battery could be low as it is adding more assist before parking.I will watch it to ensure it is not changing overnite, which would be a concern.
    Tideland Prius likes this.
  5. bisco
    51,143
  6. Danny13pruisc3
    175
    27
    maryland
    did you buy it new? what's your climate like?
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    Maybe not for a C.
    IIRC, all 4 of mine have always shown "low" when first started and then sometimes "jump" up a few bars after just a short time.
    I have assumed that there is a default shown on the display until the computer can actually determine what the effective charge really IS.
