C sound deadening Pt 1 - wheel wells
Discussion in 'Prius c Main Forum' started by garm, May 9, 2013.
  1. garm
    garm mpg + cool = win
    215
    One of my pet peeves with Toyotas is that they don't paint or sound deaden thoroughly from the factory. There are a few easy things you can do about this.
    One place they always skimp out is in the wheel wells.
    Jack up the car. Remove the wheels.
    Remove plastic trim pieces.
    Mask off all suspension and brake parts.
    Spray two coats of undercoating/sound deadener (shown in the picture, use whatever you like, thicker would be better).
    Put it all back together. Enjoy a quieter ride with less tire noise.
    Netineti, karabits and F8L like this.
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I've been meaning to do this but I wondered if it was worth the effort. I assume if you used something heavy duty it would help but I figured basic rubberized undercoating wouldn't be enough. How did it work for you?
  3. garm
    215
    ^ Besides the aesthetic improvement of not seeing half-painted wheel wells any more, it really does help suppress some tire noise. For $10 (two cans), I think it's worth it.
    I'll bet there is a thicker product that would work even better; if anyone tries it, please post up. :)
    F8L likes this.
  4. 1911Tex
    1911Tex Junior Member
    57
    17
    2013 Prius v wagon
  5. garm
    215
    ^ Cool, thanks! Maybe I'll try that on the fronts.
  6. bisco
    49,511
    f8l, let us know if you try it and if there is a discernable difference in sound. i would do this if it made a big difference.
    ztanos likes this.
  7. novasquid
    novasquid Junior Member
    49
    Northern VA
    It would be helpful if sound levels were measured before and after. Aren't there phone apps for that?
  8. garm
    215
    ^ I doubt they are sensitive enough. Sorry but it's going to be a subjective result for me, at least.
  9. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
  10. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    yea.. having added noise from the stiffer suspension and slightly inflated over spec on the tires.. i can imagine this helping only a bit for me.. but definitely adds that aesthetic improvement.
    ztanos likes this.
  11. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    How does it look when the car sitting at normal height?
  12. garm
    215
    I got two cans of the Eastwood stuff today. I'll do the front wheel wells with that product. More pics to come.
    F8L likes this.
  13. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    Is this stuff flexible enough to pull off in case you have to change a bulb in The fogs or turn signal? I wouldn't mind the sound deadening but not at the cost of not being able to pull the covers for simple bulb changes.
    karabits likes this.
  14. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    You wouldn't access any of those items from the wheel well.
    Any wires or holes/bolts should be masked off before spraying.
  15. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    I pulled it apart installing my head lamps, it's a lot easier to access the fogs from the wheel wells. The plastic just bends back and you have easy access to all the stuff behind the bumper. But does the sound deadening stuff harden up? Or does it have some give?
  16. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    The C's manual clearly says to remove the inner liner to access the headlight bulb.
    karabits and Mo G like this.
  17. garm
    215
    I wouldn't spray the inside of the bumper (that serves very little purpose in terms of sound deadening), only the wheel wells. So there is no problem with wiring/foglights/headlights.
  18. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    But you would need to be able to remove the inner fender to change the bulbs... how's that going to work? Post some pics when you are finished if you don't mind, please.
  19. karabits
    karabits Member
    51
    Minneapolis
    Yes, this is referenced on pages 413-418 in the 2012 Prius c owner's manual. Headlights aren't replaced through the wheel wells, but fog lights, front marker lights and turn signals are. But very interested in this sound deadening technique.
  20. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    You are absolutely correct. I haven't changed my heads in a while... I was thinking the fogs.
