C1231 Error Code
Discussion in 'Gen 3 Prius Technical Discussion' started by iraklisani, Jun 19, 2017.
  1. iraklisani
    iraklisani New Member
    Georgia
    replaced sensor 4 times but still get C1231 on prius 2011 ?? appreciate much if you can solve my problem
  2. 4md
    4md Member
    97
    55
    Sofia, BG
    Any other error codes? Take a look at the following document about testing the angle sensor
  3. iraklisani
    Georgia
    no thats the only code i got
  4. ChapmanF
    15,433
    There might be an INFormation code of 701, 702, or 703 that goes with your C1231, read with a Prius-capable reader, that would help narrow down the cause of the issue. The repair manual on techinfo.toyota.com will have a procedure for completing the diagnosis; turn to the skid control section, look up your code, turn to the indicated page, start following the steps and making the checks as instructed.
    -Chap
  5. iraklisani
    Georgia
    previous owner told me that he changed headlights, any chance this cause error ??
  6. ChapmanF
    15,433
    Not in a way I could think of offhand. If it were mine, I'd spend my time following the diagnostic steps in the manual ... straightest path to a solution.
    -Chap
  7. iraklisani
    Georgia
  8. J Johnson
    J Johnson New Member
    Did you ever fix the C1231 issue and if so how? I've got the same problem after replacing the spiral cable.
  9. ImranAs'hab
    ImranAs'hab Junior Member
    JORDAN
    me too
    HELP
  10. ChapmanF
    15,433
    If the problem first appeared right after you changed the spiral cable, first recheck whether the steering angle sensor is even there. :)
  11. mr_guy_mann
    mr_guy_mann Senior Member
    3,430
    1,484
    NJ-USA
    "if the angle sensor is even there"
    Meaning- if you installed an aftermarket spiral cable, did you remove the angle sensor from the old cable and put it on the new one before you installed it on the car?
    AFAIK a genuine Toyota cable assembly comes with a new angle sensor (part of why it costs so much more $$).
  12. ImranAs'hab
    JORDAN
    Dears..
    the sensor is installed but it is reading 850.5
    and dont change with steering turns.
  13. Wing Twister
    Wing Twister Junior Member
    Pakistan
    Hello did you find any solution to C1231 code and angle sensor showing 850.5?
  14. allaue
    allaue New Member
    Peoria, AZ
    Hello,
    I just wanted to post a reply in case anyone else has this issue. I saw my sensor throw a c1231 code and it was stuck at -850.5 degrees. From what I learned from various Russian & Chinese sites and videos, there is a 93c66 chip on the steering angle sensor that stores a fault code when the sensor is turned out of range and it does not clear. There are these chip readers you can use (ch341a) if you can manage to solder it and then connect to computer via USB to rewrite the code to clear it.
    I tried this, but did not have the experience or tools to do so. I ended up just buying a used Clockspring / steering angle sensor assembly from eBay and thankfully it worked.
