C1242, C1A50 in 2021 Prius after installing Aftermarket Alarm
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Lonk21, Nov 8, 2022.
  1. Lonk21
    Lonk21 New Member
    Houston, TX, USA
    2021 Prius
    Hi everyone, after learning so much from this forum for the last few months, I finally have a question of my own that doesn't seem to have a clear answer as of yet. Hoping to pick the brains of some gurus here...
    Here's the history:
    • 10/29 had an aftermarket alarm (Viper 5706V + GPS module) installed by an independent. All the alarm functions worked, but immediately upon driving the car, a whole host of brake warning messages came on. These include: PCS malfunction, antilock brake system malfunction, braking power low, PKSB malfunction. The brakes still worked just fine though.
    • 10/30 discovered the alarm had completely drained the battery, had to manually unlock the car.
    • 11/2 alarm was disconnected, battery charged. Driving the car, I noticed all the brake warning messages were still there, but they would mysteriously all disappear whenever I hit the brake pedal.
    • 11/4 left the car to sit to confirm that the source of battery drain was eliminated.
    • 11/7 battery was fine, so the alarm was re-installed with a new brain. Still, the brake warning messages persist, now constantly (even when pressing the brake pedal). The installers verified all the connections were properly made, and asked that I take it to a mechanic to further diagnose the problem, agreeing to cover additional costs. I cleared the codes with OBD2 but they came right back.
    • After the installers left, I used my Techstream to clear the historical codes (from battery discharging and installation), but the two codes remain: C1242, C1A50.
    Here's the current state of the vehicle, in case the history may contain somewhat irrelevant info:
    • Upon starting the car, brake warning messages are: PCS malfunction, antilock brake system malfunction, braking power low, PKSB malfunction. These warnings persist even if brake pedal is depressed.
    • Check engine light on with codes C1242, C1A50
    • Brake power and braking works as before and feels the same as before in terms of power and regeneration. Still getting 50+ mpg. Parking brake also works.
    • Techstream screenshots are below:
    To elaborate on the screenshots:
    • C1242 detail: open circuit in IG1/IG2 power source circuit
    • C1A50 detail: brake system malfunction
    • I ran a CAN bus check and verified that all the communications are normal and working. This was to rule out the possibility that the alarm installers may have left a harness unplugged.
    Can anyone provide any insight on what may be causing my two error codes along with all the brake warning problems? I am prepared to bring it in to the dealer, but for my own learning, I would love to explore some DIY options. I am reasonably well versed in electronics and wrench-turning, and have my own (cracked) Techstream I bought off of Amazon (which by the way is a really helpful tool).
    Thanks for looking!
  2. Lonk21
    Lonk21 New Member
    Houston, TX, USA
    2021 Prius
    Uploading the pictures here as it looks like my image uploads failed...
  3. Lonk21
    Lonk21 New Member
    Houston, TX, USA
    2021 Prius
