Tags:
  1. spycake
    spycake Junior Member
    Minneapolis, MN
    Hello. Just had the "Check Engine" light come on today, and I stopped in the local auto parts store and found 2 codes:
    C1242 - ABS $29 - Open Circuit In IG2 Circuit
    P0171 - ECM - Bank 1 System Too Lean
    It looks like the latter code (P0171) has happened before (I bought the car used), and I got some cleaner for the Mass Air Flow sensor which will hopefully help.
    Any suggestions on C1242? It was a very hot day here and I was in the middle of a bunch of little trips when the "Check Engine" light came on, don't know if that would matter.
    Edit to add: 2005 Prius. No other lights or anything came on. Added some detail to codes above.
    #1 spycake, May 29, 2018
    52,385
    never thought of the 12v for that one.(y)
  3. spycake
    Minneapolis, MN
    Thanks for the link. I replaced the 12v battery with a new Optima one just last year. System Check Mode shows proper aux battery voltages according to this procedure:
    Toyota Prius: How to Check the 12v Auxiliary Battery Health - PriusDIY.com
    Not sure what else I am capable of doing. Should I take it in, for someone to check the brake control power supply, etc.? Or just clear the code and see if it comes back?
    #4 spycake, May 29, 2018
  4. LEVE
    LEVE Member
    191
    97
    On the Willapa
    First, do the inexpensive things. Clearing the code and seeing if it comes back is one of them.
