c1253 / c2318
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ilona, Jul 13, 2011.
  1. Ilona
    Ilona New Member
    17
    Rochester, NY
    This car is a never ending source of excitment!;)
    Here we go again:
    c1253-134 / c2318 (please see attached diagnostic reports).
    I have been getting it for the last 2 years. More and more frequent each time. Last time this morning.
    Usually when car is parked. Regardless of weather. If I start to drive I hear sound similar to that made by accumulator pump every few minutes. I may be wrong but I do not think I ever hear this sound during "normal" driving.
    It is not inverter pump or engine harness, because I had them replaced two weeks ago. It is not any of the relays, because dealer tested them.
    So we have left auxiliary battery, actuator assy and harness going to it as a possibility.
    Battery and harness were causing problems in the past.
    I can pay for fixing/replacing only one of them.
    Which one?
    How to find out?
    Thanks!
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    a random google search turned up this
    http://share.qclt.com/丰田普瑞斯原厂英文手册pdf格式/repair%20manual/04pruisr/05/21avn/cic12525.pdf
    detail code 134 reads
    MTT input is 3.5 V or less for at least 0.2 sec. when main relay 1 monitor (BS1) is 9.5 V or more and motor relay 1 is on.
    since you say it's not your relays, you're left with one trouble area according to this pdf.. which is brake actuator assy. maybe the brake actuator malfunction triggered the other code?
    ABS MTR relay
    ABS MTR2 relay
    Harness and connector
    Brake actuator assy
    there are testing procedures in that link
  3. Patrick Wong
    18,200
    6,471
    DTC C2318 does imply that 12V bus voltage is low, which may be due to a failing 12V battery. Since that is the cheapest and easiest item to replace, I'd suggest starting with that. However there is no guarantee that your car does not have a more serious problem. The brake actuator will probably cost in the low four-digits to replace.
    Good luck.
  4. Ilona
    Ilona New Member
    17
    Rochester, NY
    Thank you V8Cobraqkid and Patrick!
    I have diagnostics flowcharts for both codes as well as more detailed wiring diagrams from http://zeroreality.net/prius/repair/Wiring%20Manual.pdf.
    I tried to read it with my poor English and zero understanding of car mechanics.
    Now, according to Vehicle Diagnostic Report attached to my first post for c 2318 IG(+ B value was 8.90. That's enough to trigger c2318 and indicate battery problem.
    Question: Is it enough to trigger c1253? According to one of Patrick's old posts - Yes.
    Other way around - It is ABS assy or poorly repaired connector that goes to it, which is causing this problem. It would trigger c1253.
    Would it trigger c2328 as well?
    Looking at the wiring diagram for c2318 this error happens outside of ABS area. None of the ABS components is listed as a possible causes. Although they do ask to look for other DTCs as a clue.
    So there is a chance that the answer to this question is NO.
    Am I overlooking something here?
    ABS assy was already replaced once and wiring going to it repaired.
    How much of the car do I have to take apart to be able to look at the ABS harness and do a visual inspection of it?
    I do not mean to be annoying and waste your time. I just want to do my homework and gather as much info about problem as possible before I spend any money. I have already paid a lot of cash for repairs that turned out to be unnecessary. I am getting slightly tired of it.
    Thank you for your patience and your time.
    Your answer will be greatly appreciated.
  5. Patrick Wong
    18,200
    6,471
    The skid control ECU (aka ABS) is located near the steering column. Hence to look at it, you would have to pull out the two vent ducts closest to the steering wheel, then you can remove the black plastic instrument panel covers below and above the steering column.
    I doubt that a visual inspection will tell you much; you would have to remove the wiring harness connectors and use an ohmmeter to verify continuity from a given terminal of one connector to the corresponding terminal at another connector, for example, at the brake pressure accumulator pump (aka brake actuator) located on the firewall in the engine compartment. This implies that you have access to the electrical wiring diagram so that you can identify which terminal is connected to what.
    You can do a quick assessment of the 12V battery condition by turning on the headlights when the car is IG-OFF. If the lights are dim then that is good evidence that the battery is weak.
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    The engine room fuse box is about the only thing in common with these two codes. I wonder if there is a problem with the connection there? MTT being 0V means that the car sent power to the accumulator pump in the brake actuator, and it either failed to turn on, or it failed to deliver the signal to the ABS computer that it had turned on. The fact that you got C1253 when the car was moving suggests that the 12V battery itself is not the issue, but it would still be a very good idea to rule it out.
    RP67 and SFO like this.
  7. James Folger
    James Folger Junior Member
    Sylvania GA
    Where do you guys find those PDF documents?
    I just pulled up these codes from techstream and am in the research phase.
    POA37 - 260
    P0A93 - 346
    P1116
    P1121
    P1150
    C1235 -130 / 302
    C1241
    C1252
    C1256
    C1391
    B2775
    C2318 - 20
  8. ChapmanF
    15,435
    Those are sections from the car's repair manual, which you can find here:
    Toyota Service Information and Where To Find It | PriusChat
    The manuals are copyrighted, of course, but we do have some members who feel comfortable occasionally reposting whole sections of them here. Sometimes you can find threads here on PriusChat where somebody already did.
    If you do a google search with a trouble code and site:priuschat.com then that will help you get results more applicable to Prii and not random results for what the same codes might mean in other cars. It also helps to remember some structural things, like that the second character of a code can only be digit 0, 1, 2, or 3, never the letter O, so if you spell them P0A37 and P0A93 (instead of "POA37" and "P0A93") for example, you are likely to get more and better quality results.
    James Folger likes this.
