C1300 C1241 with no symptoms - cause for concern?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusprius420, Mar 30, 2024.
  1. ChapmanF
    15,433
    The voltage readings (IG1, IG2, BS1, BS2, VM1, VM2, +B1, +B2) in those freeze frames are baaad. I'd malfunction too if I were a 12 volt ECU being powered off 6.7 volts.
    See if you can work out why such low voltages are reaching your brake system, and fix that. Things will work better.
  2. Tombukt2
    Tombukt2 Senior Member
    8,909
    1,553
    Durham NC
    Yeah you got ABS issues and your CM monitor display is out or is wonky what have you so you need to capacitors replaced on the board or buy the whole complete unit from Texas hybrids $175 with your core returned and looks like your accumulator and your ABS is running low pressure so you need a break actuator a new one is $1,400 and some change or you can play around with some used ones and get one that works might change it twice possibly three times it's happened to me right here but I can change them pretty quickly now not that big of a deal actually is it worth it that's only something you can answer in your situation.
    49,371
  4. dolj
    dolj Senior Member
    7,628
    3,849
    Wellington, New Zealand
    You also seem to be completely overlooking the C1256.
    If the reason for low accumulator pressure is that there is an internal leak somewhere in the accumulator and this causes the pump to run continuously (or nearly continuously) then that could account for the 12 V system being dragged low.
  5. priusprius420
    priusprius420 New Member
    Illinois
    You are totally right the pump does run a lot
