C1391 Advice
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Singh Saab, Oct 16, 2023.
  1. Singh Saab
    Singh Saab Junior Member
    39
    CA, USA
    2018 Prius Prime
    Hello All, our 2013 Prius Plug-in had its ABS, Brake and Traction Control Lights on the dash. I used an OBD2 scanner and found code C1391. Some searches lead to replacing the Brake Booster which the dealership also confirmed. Some videos show that the replacement is pretty simple. The dealership is going to charge $3600+ for replacing the brake booster with master cylinder and brake booster pump, after some searching I am able to get both parts for about $1200 and the dealership can bleed and calibrate for about $800. I am planning to do the replacement myself to save some money. For anyone who many know or has done this replacement do you have any suggestions or pointers.
    49,399
    watch
    watch
  3. Singh Saab
    39
    CA, USA
    2018 Prius Prime
    Thanks, already watched those. Planning to replace parts myself and have a shop in the Bay Area bleed and calibrate. They confirmed they have techstream. Dealership apparently thinks we got free money.
  4. vvillovv
    vvillovv Senior Member
    3,615
    1,272
    NY
    Repair manual recommends a pre repair scan. Might be a good idea to have the shop that is going to do the post repair calibrations, do the pre repair scan and give you that scan report to make it easier for you to follow the repair manual steps.
    ( recommended )
  5. ChapmanF
    15,494
    If the code is C1391, the title of this thread should be changed.
  6. Singh Saab
    39
    CA, USA
    2018 Prius Prime
    Where would I do that don't see any option. Mis-typed the title code is C1391
  7. ChapmanF
    15,494
    A report to the moderator can get it changed. I've made one.
  8. Tideland Prius
    16,128
    Updated the title
