C2310 P Lock (red triangle) w/ Good Battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Glen Marr, Sep 2, 2023.
  1. Glen Marr
    Glen Marr Junior Member
    I have a 2007 Prius with 205k that has been giving me a persistent C2310 code for about a month (Open or short circuit in battery circuit). I tested the battery at the terminals in the trunk and it reads 12.5V (after sitting overnight with the car off).
    The only clues I can gather from my OBD freeze frame info is: Main relay - Abnormal, Battery voltage value - 0.00v, lg(+b) voltage value - 0.00v, U phase voltage value - 0.00V, V phase voltage value - 0.00V, W phase voltage value - 0.00V.
    When I pull up live data it shows: Battery voltage value 1.25V, lg(+b) voltage value - 13.67V (U phase, V phase, and W phase are all slightly above 14V), Main relay - Normal.
    When I attempt to erase/reset the codes, the red triangle instantly comes back on.
    In addition to checking the battery voltage at the terminal, I inspected/checked to make sure the battery terminal clamps were tight and the P Con main fuse was good. I also, through some hunting around on this site, found a possible fix that I ruled out - Due to the low battery voltage on the live data, I found a similar post where someone had .62 volts (mine was 1.25) and he found the pin #13 on the transmission control computer was corroded and installing a jumper wire, which resolved the issue. I have no corrosion on that pin or within that wire harness connection.
    Any guidance anyone can provide on this as to how and what I can rule out next would be greatly appreciated.
    Thanks,
    Glen
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,470
    1,514
    NJ-USA
    According to the manual, that code sets when the voltage at pin 13 of the transmission ecu is 10V or less for more than 1 second. So I would backprobe (use a T pin or something) pin 13 (battery power) and (ground) pins 2,3, and 15- see if you have voltage above 10V constantly when you power the car on and off.
    If voltage stays where it should all the time (and no connector terminals are damaged or loose- google "pin drag testing"), then that would suggest an internal ecu fault.
  4. Glen Marr
    Thank you both for the advice. I'm guessing this issue has to be from a loose connection at the pin. I merely took the connecter apart again to visually inspect pin 13 to see if I could detect any damage at the terminal (none that I could see) and snapped it back together. The red triangle is now gone and when I ran my ODB with live data, battery voltage value was 13.59V and main relay was listed as "normal." If this pops back up I'll check the resistance to re-evaluate and confirm. My wife also told me that she hit a large bump a few weeks ago and the triangle disappeared for a little bit afterwards, which would also likely indicate a loose connection. Thanks again for pointing me in the right direction!
  5. mr_guy_mann
    3,470
    1,514
    NJ-USA
    I would look at the voltage on your scantool data while gently wiggling the connector and wire harness at the transmission ecu. See if you can get it to act up at all. Might be better than waiting for it to "fail" when your wife is driving it(?).
  6. Glen Marr
    Yeah, pretty much spot on. Today going into work the red triangle was going on and off fairly rapidly for about the last 15 min of my drive. I plugged in my ODB and the battery voltage in the transmission live data was reading about 7 volts. When I pulled into work I left the car idling and popped the hood to further look at the live data. Fortunately, I have a bluetooth OBD so that I could look at the data on my phone while wiggling the wires. I don't believe my live data is instant (seemed to be a little bit of a lag), but after moving the wires the voltage slowly went up to 10 and then back down to about 6. I'm going to take a closer look this weekend. My guess (and hope) is that it's a loose connection at lucky pin number 13. Thinking that the triangle light was coming on and off due to the car hitting a section of highway with some noticeable expansion joints that rattle the car every other second,
  7. Glen Marr
    Just wanted to circle back to this in case anyone had the same issue. New/good battery. Fuse was fine, on my OBD reading the voltage was reading anywhere from 1 to 6 volts, tested the points with a multimeter and would get 12+ volts.
    As odd as this fix seems to me, the short 8" jumper cable going from the right hand side of the fuse to the blue wire fixed it. My OBD reader shows 12+ volts now. $7 fix (for the 16 gauge wire). Wonder what that would have cost if I brought it in to a dealer garage?
  8. ChapmanF
    15,615
    Yeah, your scan tool repeatedly sends messages to the ECU in the car saying "hey, what's that voltage reading?" and the ECU sends messages back. It's not quite like watching a physical voltmeter on the connection in real time.
  9. mr_guy_mann
    3,470
    1,514
    NJ-USA
    "Wonder what that would have cost if I brought it in to a dealer garage?"
    Probably $150 an hour for as long as it took to find it and fix it.
