C342D code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pbui, Sep 6, 2014.
  1. pbui
    pbui Member
    190
    Los Gatos, northern CA
    hi folks,
    My 2004 Prius at 230Kmiles is throwing a number of codes:
    p1116, p1121 - stack valve stuff
    p0420 - AirFuel sensor, replaced rear O2 sensor but didn't help
    C342D - this one is mysterious to me, "C" denotes chassis I believe.
    does any one know of code c342d ?
    thanks
  2. Patrick Wong
    18,200
    6,479
    That is not a valid Prius DTC.
    You'll need to replace the catalytic converter to address P0420.
  3. pbui
    pbui Member
    190
    PW - You meant C342D code ? yeah, weird. May be it's my cheapy OBD-II reader. Anyway, I was afraid to learn of the Cat. Is it worth tryin to replace the AF sensor first ? I am in CA so the Cat probably will be pricey. Also I've heard these hybrids will be subjected to smog inspection starting in 2015.
    The dreaded oil burn is probably killing the cat.
