Cabin Air Filter (again) Alternative Ford parts
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by priusgto, Feb 14, 2017.
  1. priusgto
    priusgto Active Member
    194
    229
    Northern Arizona
    After the last thread on the subject , I took mine out to give it a quick dusting and ended up tearing it. Didn't take long to discover the filter for our Gen IVs is not available aftermarket and all the parts stores, according to their listings, think the Gen III filter is correct which it is not. So I did a little detective work and came up with an alternative which, with a few scissor snips, fits perfect.
    Yes, it's a Ford part from a 2012 Taurus and was only 6 bucks from Autozone. Rockauto.com has these for just over three bucks if you want to save even more.
    The width is as perfect as it can get
    The length is only a pleat or two too long
    The height is about 3/8" shorter but, I have an idea for using that to our advantage
    A few snips of the scissors and it is the correct length and fits the cage perfectly. I removed the end stiffener and used a hot glue gun to reattach it after the cut but it's not really necessary.
    Now to fill in the rest of the space. An HVAC (cut to size) filter picked up at Home Depot for 10 bucks. This filter will make 6 disposable pre-filters and extend the life of the cabin filter and has a carbon layer also.
    Cut to size, the pre-filter fills in the space from the shorter cabin filter
    Done! After installed, I can't tell any appreciable difference in airflow but I will test it with my anemometer in a day or so and report the results.
    FuelMiser, RCO and bisco like this.
    51,155
    i paid $26. for the oem.:unsure:
  3. priusgto
    194
    229
    Northern Arizona
    Hopefully for the last time.
    RCO likes this.
    51,155
    you got that right. is the gen 4 filter a different size from the 3?
  5. priusgto
    194
    229
    Northern Arizona
    It's almost the exact size but the pleats run in the opposite direction so the filter won't drop over the divider in the cage.
    RCO likes this.
  6. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    You are helping keep the business in the black, you know.
  7. bisco
    51,155
    good point, wouldn't want my dealer to go out, what would i do for warranty? or where would i buy my next?
    RCO likes this.
  8. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Philosophical hat on for this one: "many a true word is spoken in jest."
  9. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    $12 from Amazon that fits like it should.
    RCO likes this.
  10. priusgto
    194
    229
    Northern Arizona
    Brand? Part number? Which vehicle? Your signature says you own an 11 and 13.
  11. Neohippy
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    Both take the same filter. Any auto parts store also sells them fairly cheap
  12. priusgto
    194
    229
    Northern Arizona
    Both of yours yes, but we're in the Gen IV forum talking about a Gen IV and the only available "correct" filter for the Gen IV is OEM which is overpriced.
    Prodigyplace and RCO like this.
  13. Mendel Leisk
    40,584
    What about dealership?
  14. priusgto
    194
    229
    Northern Arizona
    Spent the afternoon comparing the difference in flow between the two filters and OEM is definitely the least restrictive. I averaged the flow between vents and also fan speeds. Below is the percentage of flow for each filter compared to 100% flow of no filter installed.
    OEM - 93%
    STP - 86%
    STP w/prefilter - 73%
    RCO likes this.
  15. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    According to the FRAM online catalog, the CF10285 cabin air filter is listed for the 2016 Prius. None is listed for 2017.
  16. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    You could always leave it out if stuck. Personally I'd have put the torn one back in if it was clean and wait for aftermarket ones to become available.
    Mendel Leisk and RCO like this.
  17. priusgto
    194
    229
    Northern Arizona
    That"s the one for the gen 3, about the right size but the pleats are running in the wrong direction to fit the gen 4
    I'm going to order different brands from Rockauto to compare the flow restriction with OEM. Hard to say when an aftermarket filter will become available but I may keep using the OEM until one does.
    RCO likes this.
  18. Mendel Leisk
    40,584
    Total agreement: this is not the engine filter. IIRC I did ask up the page: does the dealership have the filter?
    RCO likes this.
  19. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    Resurrecting an old thread. Purchased a used 2018 Prius Four Touring, 22k miles, CPO, so the dealer prep included new cabin, new engine air filters.
    I just checked mine. Are the OEM filters pure white, no charcoal, and incredibly flimsy? I thought I saw an OEM that was dark gray, rather stiff. Also, the filter element was upside down (clearly marked with an "UP" arrow).
    Did my dealership go cheap and NOT replace with an OEM filter? Yes, flow is critical (this filter looks so thin, probably no restriction whatsover), but filtration, IMO, is just as important.
  20. Mendel Leisk
    40,584
