cabin air filter carnage
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Robert W. Horsey, Aug 26, 2016.
  1. Robert W. Horsey
    Robert W. Horsey New Member
    Rehoboth Beach, DE
    I bought a 2010 Prius IV at 88,000 miles and found this last night festering in the dash>
    The last one shows insulation that was sitting on top of the filter. It looked like mice
    were living in that nice warm nook.
    -Robert
  2. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    go check underneath the plastic below the wipers/....
    just saying/
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    If I remember right the original advertising slogan for the Gen 3 was "Harmony Between Man, Nature and Machine".
    Looks like rodent- nature- got a little too harmonious with your Prius.
    Kind of amazing that it got that bad and evidently never smelled too bad.
    Or did you notice any odd smells?
    Those pictures are a diet aid.
    malmon and WilDavis like this.
  4. StarCaller
    1,246
    697
    looks like he just bought the car/
  5. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    Looks like the work of Mr. Mousie! (I had similar problems with my old 1993 Corolla DX Wagon - despite it being garaged) - solution was to leave some mothballs aroung the skirting boards (worked like a charm!)
  6. Robert W. Horsey
    Rehoboth Beach, DE
    That's a good recommendation to check under the cowl for more carnage.
    I've had the car for about 1 month. It is a peach. My other car is a Lotus Exige S240
    so the Prius drives like a Rolls Royce to me. (not that I've ever driven a RR)
    The coolest part about the car is the Solar Roof Package: it has the remote
    AC and vent
  7. Robert W. Horsey
    Rehoboth Beach, DE
    There is a flap above the air filter location that appears to have been gnawed on by a rodent.
    Will this pose a problem? What is the flap's purpose?
  8. WilDavis
    2,492
    2,153
    49
    Is the flap spongy? (that's what it looks like) Might be able to replace it with another piece or fabricate one from a piece of sponge foam. I think I'd be more worried about teeth marks on wiring harnesses or connectors. Good luck! (BTW Welcome to PriusChat!)
  9. yeldogt
    yeldogt Active Member
    810
    313
    NE
    It is a bypass vent -- it's just a rubber flap. I think it's to make sure the system is not starved for air should the outside intake become blocked.
  10. Robert W. Horsey
    Rehoboth Beach, DE
    The material is some type of stiff vinyl fabric. Thanks.
  11. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    The flap acts as a sort of one-way valve to allow some interior air to bypass into the HVAC system when the fan is on, but block unfiltered, unheated, uncooled outside air from coming out through those holes---which would happen mainly when driving at high speeds with the fan off.
  12. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    There is a way to block mice from coming in. It entails small-gage galvanized wire available in good old-timey hardware stores, and some sheet metal screws. There are threads on mouse proofing on this forum. One of the mouse entryways is on the plastic cowling under the windshield wiper on the passenger side (pretty close to the cabin filter). Another entry way is behind the 12 volt battery in the trunk. With some time and patience, it's not a hard modification especially since they found their way in once.
