Cabin air filter was jammed in
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mr. King Andrew, Aug 12, 2019.
  1. Mr. King Andrew
    Mr. King Andrew Junior Member
    17
    I just bought a 2010 Prius Five and went to install a new cabin air filter. I found that the old air filter was carelessly jammed in and basically half crushed, so it wasn't covering the whole air intake (only about half of it).
    It wasn't insanely dirty, but there were a few leaves on it and quite a bit of dirt/dust.
    So what kind of damage may have been done by this? How would it be fixed?
  2. JC91006
    16,482
    8,400
    There is no damage done. Just put in a new filter.
    Not having a filter is the same as breathing fresh air. The filter would filter out things like.....leaves
  3. ETC(SS)
    6,554
    Damage only to your ego.
    dig4dirt likes this.
    49,482
    when i tried a fram filter, that's exactly what would happen every time i tried to slide it in.
    it's been oem ever since
  5. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Same as what happened to HVAC system of every vehicle back before cabin filters were a thing.
  6. bisco
    49,482
    blows the leaves out the center vents into your eyeballs?
    mikey_t likes this.
  7. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    Saved for future signature quotes.
    RMB, Raytheeagle and bisco like this.
  8. Mr. King Andrew
    17
    Which is what?
  9. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Or perhaps the leaves and dead bugs lodge in the heater core?
