Cabin air filter
Discussion in 'Gen 3 Prius Technical Discussion' started by Smirv, Jun 24, 2010.
  1. Smirv
    Smirv AkA: Ryan
    212
    Illinois
    What is the difference between the cabin air filter in the III and the ionized air filters in the IV and V???
  2. RiceHead
    RiceHead New Member
    Boston, MA
    Ionized filters use an active static electricity charge, usually to attract dust particles and/or pollen.
    Ionizing filters are also used in some of those silly home air filters that are sold at places like Brookstone (and now everywhere else too!). These have come under a bit of scrutiny because of the ozone emissions they produce are thought to be harmful to the health (esp for those with asthma). In all honesty, I would just go with the normal filter, but that's just my 2c.
    2 people like this.
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    The Plasmacluster ionizer in the IV and V is seperate from the cabin air filter, the cabin air filter is the same in all four Prius versions. The Plasmacluster thing is supposedly located in the drivers side dash air vent and operates when the AC is on. I have no idea if it does any good or not, fortunately I am not alergic to dust and pollen.
  4. Prius42
    Prius42 New Member
    139
    Maryland
  5. tumbleweed
    4,067
    687
    Eastern Oregon
    The cabin air filter fits behind the lower glove box, there are instructions for replacing it in the Owner's Manual.
    The only other air filter I know of is the engine (ICE) air filter under the hood.
    Both are easy to change and available at any Toyota dealer and most auto parts stores.
    http://priuschat.com/forums/gen-iii...ement-engine-air-filter-cabin-air-filter.html
  6. danielthechskid
    danielthechskid New Member
    Centerville Iowa
    The regular air filter protects the ICE from dust, the cabin air filter protects the A/C evaporator from dust, after the switch to R-134a refrigerant many auto makers used thinner metal to make the evaporator core and they started leaking due to dust and pollen buildup causing corrosion, Chrysler LH series cars are famous for this.
    Even in your home the filter on the equipment is there only to protect the equipment, it isn't there for your health. If you have an 80% furnace with no A/C a cheap spun fiberglass one is fine, if you have a 90% furnace and/or A/C a pleated media filter 2" thick or more is better, but avoid the ones listed as allergen filters such as the 3M Filtrete line unless you measure the static pressure of the system as they are too restrictive and are lovingly known as crack-o-matic for what they can do to furnace heat exchangers.
  7. johnmaci
    johnmaci Junior Member
    30
    MD
    Thanks for this information!
    No one had ever said anything about this and I have had several occasions where the air would just run slowly and condensation would start building and leaking from the ducts (wierd)
    It makes perfect sense....
  8. bayowolf
    bayowolf New Member
    The ionizer is also used to eliminate odors and as such is great when passing a skunk and similar odors , and is also good when following someone with a stinky catalytic converter , etc.etc !
  9. El Dobro
    El Dobro A Member
    6,979
    3,214
    Just use the carbon imprenated filters, they take out odors, too.
