Cabin filter - alternative
Discussion in 'Gen 2 Prius Accessories & Modifications' started by cireecnop1, Feb 21, 2008.
  1. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    So today I replaced my cabin filter with a cut-to-fit 3M filtrete(sp?) furnace filter. I went with the 1250 ultra alergen rating just to try and counter the emissions of those diesels that I always find myself behind. but now i noticet the fan is slightly louder and the air flow is kind of restricted. Can this cause long term damage to the fan motor? since the the air flow is less im sure it will cause my ac to run longer in the winter, should I replace it with a factory one by the time summer swings around?
  2. Flying White Dutchman
    4,374
    313
    i really want to see some picture's if you have them?
    and i think when the airflow is less inside the car then it Will take longer to cool/warm the car or the AC Will go to a higher fan speed.
    so maybe you use more fuel and the savings of this cheaper DIY air filter replacement go's away
  3. patsparks
    10,664
    567
    Adelaide South Australia
    Get a proper filter.
  4. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    There is no furnace filter that will "Counter the emissions of those diesels".
    Just hit the recirc button on the wheel to keep from sucking it into the cabin.
    The cabin filter is reusable, a little detergent and warm water will clean it up just like new.
  5. sugar land dave
    137
    houston
    I don't like the motor's chances of survival in that circumstance. Why gamble? Go back to OEM and as the previous post suggests, use recirculate.
  6. donee
    donee New Member
    2,956
    197
    Chicagoland
  7. johnford
    johnford Old Junior Member
    105
    Malvern, AR
    Any thoughts of using a carbon filter, or hepa filter to do a better job than the factory filter. I hate it when I turn on the air in a 3 month car and it stinks. Being a non smoker, I seem to notice the smell more.... jf
  8. tochatihu
    tochatihu Senior Member
    9,045
    3,528
    Kunming Yunnan China
    2001 Prius
    No doubt you could rig something up with activated charcoal. As far as commercial filters, anything that fits in the tray (about 1 inch thick) ought to be fair game. But if it is obviously making the HVAC fan motor labor, that will probably end up costing you some money.
  9. cireecnop1
    338
    Pueblo, CO
    I just dont feel comfortable with the original filter its rather "see through" I was gonna place a charcoal filter on it as well but didnt feel like it was smart to do both mods. I was slightly joking when I said "counter the emmisions of diesels" but I do think this filter is better than the original. besides I think it will filter more than the original even if it was as 'see through' since the ridges on the new one are larger.
    ok this is the best picture I could do with my cell-phone.
  10. Flying White Dutchman
    4,374
    313
    looks nice and oem
  11. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Way too much particulate matter enters the cabin through opening doors and windows to make a low-pass HEPA-style filter very effective. The OEM filter is designed to strain out the big chunks and bugs, not give you a cleanroom. If you object to the Toyota filter (available fairly cheaply online), Bosch makes a filter that's a little beefier and the right size. What's the point of using a Filtrete filter when you have big gaps around the edges?
    It's easy to add an activated carbon filter. Honeywell makes "universal" carbon filters for their room air filters. The material comes in a roll, just cut a square the same size as the OEM filter and set it on top of the pleated filter. It does help a bit with stinky exhaust from outside, or inside.
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    I have the Ecoquest air purifier. Its helping to get rid of the ac smell. I have had it about 2 years and finally got around to putting it in the Prius. It works really good. I tried loading a pic but got a database error. I think cause its 3m pic. Forgot to take a smaller image.The link below is to there brand new one. There pricey but they really work well. There strong enough to use in your house and come with a wall wart.
    - No Installation Required
  13. edthefox5
    10,096
    4,804
    Clearwater, Florida
  14. PriusFan808
    PriusFan808 New Member
    35
    Pensacola, Florida
    I too have been looking for a better-than-OEM cabin filter that would help with my allergies. Coastal is no longer able to get the PIAA filter from Japan that was able to arrest particles under 1 micron. Check out the WIX brand, or the BLITZ reusable, both available at the Coastal website. The WIX is actually pathogenic; it will kill bacteria by stabbing them with microscopic spikes that cover the filter. Pretty cool, eh? The blitz has a Titanium Dioxide coating that "renews" the filter when placed in the sun (after wahing the filter, of course).
  15. hefaust
    hefaust New Member
    32
    Indianapolis, IN
    You could void your warranty if you're still in the 3/36 bracket. If your fan motor quit working and your dealership saw your furnace filter, your warranty claim would be denied. As another poster stated "use your recirc button". Since I draft off of semi trucks to keep my stellar 58mpg highway mileage, I use my recirc button often with good results. Again, stick with OEM.
  16. tochatihu
    9,045
    3,528
    2001 Prius
    I agree with Hefaust that the HVAC fan should not be overloaded. This is easily seen too; listen to the sound of the fan with an OEM filter, no filter and your alternative filter. If the latter one noticeably lowers the pitch, it is not a good choice.
    The vast majority of the alternative filters discussed at PriusChat will not cause any problems. As always, judge for yourselves.
  17. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Stabbing the germs?? I find this hard to believe!
  18. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
  19. Jiipa
    Jiipa MGySgt USMC (Ret)
    314
    Oahu, Hawaii
    Do germs feel pain when they get stabbed?
  20. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    I sure hope so! :brushteeth:
