Cabin Filter: Original vs. Fram Fresh Breeze
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by toyolover, Jan 5, 2011.
  1. toyolover
    toyolover Member
    441
    67
    toronto, canada
    Please see the picture for the two comparison.
    The factory one on the right is after 12 months of usage. The Fram on the left is brand new.
    The factory original has about 34 fins, the Fram Fresh Breeze has about 14 fins.
    The Fram unit has baking soda and carbon combined in the filter. Fram is about half the price of the Toyota original.
    I don't know which one is better at this moment until another 12 months of usage but I am happy for the savings.
  2. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    The more pleats the larger the surface area, so more filtering on the OEM filter. CFM air flow should change as well. Will the Fram still work...sure. My 02.
  3. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Not to start any flames except if the Fram is of a better quality filter media they would not need as much of it to get the same results as the OE filter.
    I like the idea of a fresh filter......since my wife is a smoker...
    Will watch this post to see how well the Fram does
    Keep us posted.
  4. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    I just bought the fram filter and placed it in my car. The nullification of smells with the carbon filter makes the fram worth it over the OEM filter IMO.
  5. Hidyho
    Hidyho Senior Member
    2,698
    529
    2018 Prius
    I concur, I use the Fram and it seems to make the air smell better.
  6. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    you can but oem with carbon filter
  7. macmaster05
    macmaster05 Senor Member
    4,050
    727
    I know some ppl just buy a standard filter and leave an air freshener on it.
  8. rpeeples
    rpeeples Experienced Toyota Owner
    109
    America's own third-world country
    I have not been able to locate one yet. Where did you get yours?
  9. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I got it from Walmart.
  10. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Cool. Let us know how well the filter works keeping things fresh. Since your wife smokes it should be a good test of the element. Thanks!
  11. ETC(SS)
    6,490
    I'd probably try the Fram unit, unless they put some goofy scent in it.
    My $0.02.
    My company will almost certainly not buy a CAF for this car, so if/when it gets changed, it's probably gonna have to come out of my pocket.
    Let us know how it works, pleaase.
    GOOD LUCK!
  12. peterjmc
    917
    188
    Clarksburg, MD
    I like this!
  13. hyo silver
    hyo silver Awaaaaay
    15,232
    1,562
    off into the sunset
    I misread the title as 'farm fresh'. :D
    After washing the original filter with nice-smelling soap and sprinkling some baking soda on it, the interior air quality improved noticeably.
  14. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    I'll probably try a Fram anti-stink filter too. If you are trying to avoid spending money on your company car, have you noticed that people have successfully washed their CAFs?
  15. ETC(SS)
    6,490
    No I didn't! Thanks for the tip.
    I do not know know why I didn't think about that----:rolleyes:
  16. CTpriusV
    CTpriusV Junior Member
    70
    Bristol Ct
    DO you have the Fram number TIA
  17. peterjmc
    917
    188
    Clarksburg, MD
    Fram Fresh Breeze Part No: CF10285
  18. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    I put in the Fram CAF recently. I noted that it didn't fit as well as the OEM - I had to squash it a bit to get it in. Fram may have made it a bit too thick. The one I purchased claimed to have filtering properties like the 3M Filtrete furnace air filters, in that the material would electrostatically trap very small particles.
  19. nicoj36
    nicoj36 Active Member
    495
    156
    Sorry to revive such an old topic post, but I need to ask which direction of the arrow on the Fram Fresh Breeze filter should it go in? The arrow on the Fram filter says air flow, but the arrow on the OEM toyota filter says up? How would I go on installing the Fram filter? arrow pointing up or down? Thanks and sorry again for the post.
  20. jzchen
    jzchen Newbie!
    3,296
    1,006
    Arcadia, CA
    Did you notice if the dirty side of the old filter is up or down? That would be the side air flows into the filter. Arrow would point the other way.
    I think the correct way of cleaning is with compressed air, not washing.
    SCH-R530M ?
