cabin lights
Discussion in 'Gen 2 Prius Main Forum' started by bonesrn, Nov 18, 2005.
  1. bonesrn
    bonesrn New Member
    Oakland CA
    I have a 2005 Prius in Oakland CA... I get out of the car when I park after work... close the front door... then open the rear door and get out my lunchbag.. close the rear door then press the button to lock it.... it beeps the lights go out and then in a short while... @ 15 seconds the lights go on again.... stay on for a while... and then go off... all with me not touching it or the transponder?????
    any suggestions?????
  2. aaf709
    3,862
    2022 Prius Prime
    Do you observe this from afar, or when you go past it? Every time you approach (or just go by) the car (assuming you have your fob with you), the interior lights will come on. You don't have to touch the car. The lights come on even if I'm just going past to take out the garbage. It startled me the first time it happened.
  3. jeromep
    jeromep Member
    827
    Eastern Washington State
    Yep. That is smart key at work. If you car is locked and you walk by the passenger doors with the key on your person the car goes ito a pre unlock mode. That mode activates the interior lights for you. That will not happen if you approach the back of the car before approaching the sides. The smart key system will not poll the transponder on the back door until you lift the handle. If you notice, with the car locked, if you open the back hatch before you unlock the side doors the hatch will take some time for it to unlock. Usualy the sequence is grab handle, wait fraction of a second, car beeps, hatch releases, doors unlock. This is because, as soon as you grab the release handel on the hatch, that is when the car looks for the smart key. The car verifies you have the smart key and then unlocks. Unlike the side doors where the car is prepared to unlock for you before you grab the handle.
