Featured Cadillac CT6 RWD PHEV drivetrain detailed
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by carpedal, Feb 25, 2016.
  1. carpedal
    carpedal Member
    37
    57
    Centreville, VA
    49,393
    sounds nice, i hope it does better than the last one. price?
  3. Trollbait
    11,511
    The last one was a prettied up Volt with minor performance improvements. This one should be a better 'value' in terms of performance and being a bigger car.
    The value remains to be seen. The ICE model has a base MSRP of $53.5k to $67.6k. This is Cadillac's new flagship.
    Cadillac | CT6 Sedan
  4. hill
    8,158
    Why so few clutches & gear sets . . . . . . after all if more is better. Oh wait I forgot - 50% or more of auto profits come from the service garage.
    :rolleyes:
  5. Trollbait
    11,511
    How often does an automatic transmission clutch pack have to be replaced?
    Fluid changes might be more often, but the 50k or 100k mile interval most have now is better than the 30k mile one on our 2001 Sable. Then the dealership likely charges the same whether it is a step automatic transmission or an HSD transaxle.
  6. telmo744
    telmo744 HSD fanatic
    2,178
    768
    Portugal
    The dealer cannot charge the same. HSD transaxle oil lastes for much longer, and it is only drain/refill.
    Step automatic transmissions, with solenoid valves, carry a lot more oil, filters and work to be done when flushed, and must be performed properly.
  7. austingreen
    austingreen Senior Member
    13,569
    4,105
    Austin, TX, USA
    5 clutches are probably better than 0 ;-) Really I think they could have done with 4 clutches and more gears:)
    I doubt it will need that much service. Most of the time it will simply be clutched to be in bev mode with that big battery. It sounds like a lot less wear and tear than the 4 speed + cvt Lexus version of 2 mode
    8 things you should know about the Lexus LC 500h powertrain
    I don't think this will do well compared to the lower cost bmw phev the 330e. The 330e only has about 17 electric miles, but it is based on a better platform. This caddi will likely fall between the Lexus model S 90d and the bmw 330e. I think people if they aren't caddi devotes will pick the beemer or the tesla. 0-100 km in the caddi is 5.6, the beemer 6.1 the tesla well the p model will do it in around 3 seconds, without the p its still much faster than the Cadillac.
    BMW raided the volt team for tallent. The 330e takes some strange design choices but reduces hp on its 2L turbo for efficiency in charge deplete mode, getting only 250 hp from the combination. The cadillac will be a much better bev, but ... if that's what you want it won't come clsoe to the model S. The bmw uses a double clutch transmision then a clutch between the motor and engine making it 3 clutches (2 used to switch gears in bev mode, a thrid for hybrid mode changes.
  8. Trollbait
    11,511
    Perhaps in Europe, but in America all the dealers are independent(except for Tesla). So they'll charge what they think they can get away with. My Toyota dealer wanted $80 just to inspect the belts and other rubber parts.
  9. telmo744
    2,178
    768
    Portugal
    Some even refuse to do the "lifetime fluid", so with a HSD we just can keep running for several hundreds of Thousand miles. The other trannies, not quite...
    #9 telmo744, Feb 29, 2016
  10. Trollbait
    11,511
    There is some automatics with lifetime fills.
    It is just lifetime to all car companies is just 150k miles or so.
  11. telmo744
    2,178
    768
    Portugal
    Watch some DSG problems if no servicing, just google it.
  12. Trollbait
    11,511
    I was referring to the step transmission in the HHR.
