Cali SMOG Certification needed
Discussion in 'Gen 2 Prius Main Forum' started by rocketrob, Dec 15, 2015.
  1. rocketrob
    rocketrob Member
    104
    Los Angeles
    DMV registration on my 2007 Prius is due for renewal and, for the first time, it requires SMOG Certification. ugh. Evidently, this is DMV policy as of April 2015.
    According to this DMV FAQ, the new testing procedure for hybrid vehicles consists of a visual inspection and OBD scan. Tailpipe emissions testing is NOT required.
    More info here about the SMOG test station needing a newer "BAR-OIS" OBD scan software in order to be compatible with hybrid vehicles. The older "BAR-97" equipment is not compliant.
    I'm not excited about any of this.
  2. Patrick Wong
    18,210
    6,511
    It is somewhat funny that the first question / answer in the FAQ mentions the motivation for implementing smog checks is to find long-term deterioration - yet a tailpipe test is not performed. Hence the smog test is basically to confirm no warning lights are on, and maybe to make sure the owner did not have a cheap aftermarket catalytic converter installed.
    Montgomery and orenji like this.
  3. orenji
    orenji Senior Member
    5,887
    3,488
    Just a way for California to make more money off us!!:mad:
    sfv41901 likes this.
  4. vskid3
    vskid3 Active Member
    773
    228
    Thank goodness they have smog inspections and don't have safety inspections. A missing catalytic converter is so much worse than brake lights that don't work.
  5. luckyboy
    luckyboy Member
    204
    29
    yup, a friend had to spend a couple grand at the dealer for an OEM cat to smog on his 2006 prius last month. The CEL light had been on for 30K miles but he thought it didn't matter until the new smog rules for hybrids came into place...
  6. rocketrob
    rocketrob Member
    104
    Los Angeles
    What happened to the original catalytic converter?
    #6 rocketrob, Dec 16, 2015
  7. JC91006
    16,782
    8,576
    2006 should be under warranty if under 150k miles
  8. Patrick Wong
    18,210
    6,511
    They seem totally related to me because if the friend was not facing the need to pass a smog emissions test, he would continue to ignore the CEL for another 30K miles or more, thus adding more unneeded pollution to the marginal CA air quality.
    Silver bullit likes this.
  9. rocketrob
    rocketrob Member
    104
    Los Angeles
    I see your point. That smog testing provides control and monitoring of vehicle emissions.
    In my mind, it's unfortunate that enforcement is needed. CEL lights exist to tell you that something is wrong, don't just ignore it.
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I totally agree
    orenji likes this.
  11. luckyboy
    luckyboy Member
    204
    29
    I guess it finally wore out, he had 199K when he replaced it but said it still looked like new
    I mean the prius is PZEV, I'm sure it was still polluting way less than the majority of cars even with the CEL and the cat was just bellow an arbitrary threshold. If you are looking for someone to blame find a TDI owner
    #11 luckyboy, Dec 17, 2015
  12. JANSone
    JANSone JANS one
    87
    OC, CA
    resurrecting this thread as i tried to get a smog check yesterday but my car DLC was preventing a connection with the OBDII testing tool.
    just now tried getting any error codes off my OBDII bluetooth scanner but even that couldn't maintain a connection.
    have an appt tomorrow with an auto electric repair shop to diagnose & repair, but just wondering if anyone ever had any issues with their DLC port & connecting OBDII devices...
  13. Scarface2005
    Scarface2005 Member
    93
    47
    San Bernardino Mountains
    Just posting an update, as I’m about to help a friend with his gen2. My successful experience several years ago was this...
    Let the car run on low oil, ie half of the threshold
    Changed the cylinder 1 spark plug
    Cleaned the throttle plate
    Cleaned the MAF sensor
    Poured some 99 cent fuel additive
    Filled up
    Drove THE **** out of the car 1200+ miles
    CEL and monitors turned off
    Passed smog
    I had let the 05 Prius with 180k sit, in the cold, for too long as we had a big snowstorm and I had to drive the 4x4. Yes, we do get snow in California.
    The next winter, same code came back under the same conditions. But, smog is every two years. So, I didn’t do jack shit. The code cleared on its’ own. I was commuting 800 miles a week. This is what I’ll stress about my experience with an 05 Prius. The Prius likes to be driven!!!!
