California to require new buildings to prep for electric charging stations
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Ashlem, Oct 27, 2014.
  1. Ashlem
    Ashlem Senior Member
    754
    502
    WI
    2017 Chevy Volt
    CA To Require New Buildings To Be Prepped For Electric-Car Charging Stations
    So, what's your opinion? Obvious evolution of electric car infrastructure, or government getting in the way and adding unneeded expense? Keep in mind that this only applies to new buildings going up, not for ones that are already in place.
    I'd imagine putting the installation in for an electric charging station while you're putting the building up would make it easier and cheaper in the long run than installing it afterwards.
  2. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    ...California/CARB has pledged to do "what it takes" to make EV option viable in CA. So they just gotta look for ways to prepapre the state for a sizeable population of EV's and plug-ins. Whether or not the specfics of the proposed bill makes sense, generically it makes sense to plan ahead.
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Absolutely. The same prep idea should apply to PV too.
  4. austingreen
    austingreen Senior Member
    13,572
    4,109
    Austin, TX, USA
    Doing this is pretty cheap compared to a lot of the california building codes. They just are requiring the wiring and power box for charging stations. The utility here is encouraging all new homes and offices to do the same thing, but its a recommendation not a requirement.
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It's great. Every building should have at least an outlet that is available to use. The paradigm shift of fueling at fuel-stations to fueling at your destination will take a long time.
    I had to fill up the Prius yesterday, first time in a while. Don't miss it at all. I much prefer the couple seconds it takes to plug in the Leaf.
    Ashlem and austingreen like this.
