Caliper bolt behind the sliding pin won’t go in
Discussion in 'Gen 3 Prius Technical Discussion' started by Hybrid3000, Apr 10, 2021.
  1. Hybrid3000
    Hybrid3000 Junior Member
    23
    Maryland
    Two Eco
    Guys im sitting in my garage trying to get this bolt to go in, its the bolts behind the sliding pins, it’s like they’re not even the sane size anymore and won’t screw in, any help would be amazing. Nutzandboltz video seemed so easy but i feel like im in over my head, don’t know why these bolts aren’t screwing in?
  2. Hybrid3000
    23
    Maryland
    Two Eco
    Its these bolts right here
  3. Hybrid3000
    23
    Maryland
    Two Eco
    i got the top one to go in by moving it a little bit but the bottom is not going in it just keeps on screwing and not tightening
  4. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    Your caliper is probably not aligned properly with the sliding pin. Take the sliding pin out, inspect the threads, and try screwing the bolt directly into the pin.
    Raytheeagle and Mendel Leisk like this.
  5. Hybrid3000
    23
    Maryland
    Two Eco
    Its not aligning right for some reason, excuse my nubeiness, but what’s a thread? I did lube the sliding pins, how would i screw the bolt into the pin? Because it has to go through the caliper
  6. Hybrid3000
    23
    Maryland
    Two Eco
    Ok i screwed the bolt into the sliding pins after i took the caliper and hung it up again with a bunggee and they’re screwing in, i just cant get the calpier to align
  7. ChapmanF
    15,104
    Just takes some patience and finessing. Get it close ... get the bolt started into the pin on one side ... leave it fairly loose ... get the other bolt started in the other pin, wiggling the caliper around until it gets a clean start. You can also push the pin inward so there's a gap between it and the caliper, easier to see your bolt passing through the caliper and starting in the hole.
    Wait until both are well started before tightening either one down.
    This kind of thing becomes second nature after a while, but it's new to everyone once.
    Tande, Hybrid3000 and Mendel Leisk like this.
  8. tre4xw30
    tre4xw30 Junior Member
    37
    US
    If they are sized then I would just buy a new caliper.
    SM-N986U1 ?
  9. tre4xw30
    37
    US
    Seized*
    SM-N986U1 ?
  10. Hybrid3000
    23
    Maryland
    Two Eco
    Trust me i tried doing exactly what you said but eventually i checked out the piston opening and it wasn’t aligned, once I aligned it the caliper fit on like a glove!
    sLick415 likes this.
  11. Hybrid3000
    23
    Maryland
    Two Eco
    Man i really hope I don’t run into a seized caliper, I don’t even know what it looks like. Haha. I eventually got it the piston wasn’t aligned properly so it finally fit after getting that down
  12. Hybrid3000
    23
    Maryland
    Two Eco
    Oh and just to let you guys know the Toyota dealership told me my rear brake pads gad 4mm left and were in the danger zone at 100k miles, well, they were just a little more worn then my new ones so I didn’t change them and just used some brake cleaner, my rotors looked just a little rusty but still almost new! Thought the dealership would be more professional then a small town shop!
    tre4xw30 likes this.
  13. Mendel Leisk
    38,247
    With the rears were you careful with piston orientation? It should go back together with the 4 spoke pattern on piston face oriented like an X, and STAY thus, be well seated in that orientation.
    Raise the rear and check the wheels spin semi freely, to verify all is ok.
  14. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    "Danger Zone" is not an official Toyota term. Brake pads are good down to 1mm. See attached from 2010 Repair Manual...
  15. Mendel Leisk
    38,247
    Mmm, Toyota says minimum acceptable thickness is 1 mm. But when you’ve got the set of pads out, and they’re 2~3 mm at most, bits coming off the edges, and sorry looking?
